Old 26-10-08, 12:05 PM   #11
Default Re: GSXR750 K7 Front End (90%) Done
No you don't mix yokes, you use the SRAD ones. I think you use SRAD spindle too.
Yes it's not a direct fit for whole front, you need to mix and match a bit. SRAD front is easiest, bolts straight on with just a different bearing and everything except speedo works as standard.
Old 26-10-08, 12:16 PM   #12
Dangerous Dave
Originally Posted by shelleyamy View Post
The steering stops don’t work, but until I get the new clip-on’s, I can’t tell if this is a issue or not.
It will if you have a light off, it will dent the tank.
Correct.
Old 26-10-08, 12:18 PM   #13
And really hurt if you have a bit of a wobble.
Old 26-10-08, 02:03 PM   #14
amnesia
...I do remember,(but can’t find the thread/picture) one that was fitted on the inside of the front fender.
http://forums.sv650.org/showpost.php...3&postcount=37
Try there, although I did have a problem with the magnet spacing. I changed the sensor for a smaller one, but the mounting location was the same.
Old 26-10-08, 02:58 PM   #15
shelleyamy
That's the one, thanks
Mike
Old 26-10-08, 04:06 PM   #16
amnesia
...although I did have a problem with the magnet spacing.
By magnet spacing what I really mean is that my sensor was too close to the magnets causing erratic readings at low speed and a large over-read at higher speeds. A smaller sensor meant that I could increase the sensor-magnet gap so that it worked.
Old 26-10-08, 04:10 PM   #17
That avatar still makes gixxer front end threads far more interesting.
Old 26-10-08, 04:22 PM   #18
shelleyamy
I am going to copy your setup. Can you point me to the right sensor and magnets,and where you got them, (i think you got the magnets from ebay).
Thanks
Mike
Old 26-10-08, 05:22 PM   #19
amnesia
You should see the rest...
Anyway, back on topic... ( )
SENSOR - Hamlin 55100-3H-02-A
The sensor I used was one of these:
http://uk.farnell.com/hamlin-electro...nge/dp/5052567
The xx-xx-x part of the ident number defines the wire terminations and length, and the activation range. The datasheet .pdf on the farnell website gives the details.
MAGNETS - Neodynium discs
From here:
http://stores.ebay.co.uk/PowerMagnetStore
The size will depend on how you are going to fix them to your discs. I used disc magnets about 8mm diameter and 3mm thick. I used araldite to glue a small nut one side, then glued the nut into the disc rivet. You can get them with countersunk holes predrilled too
MAKE SURE YOU GET THE MAGNETS THE RIGHT WAY ROUND!
I needed eight, but you might need four - you will need to have a scan through a curvy conversion thread to confirm how many you need.
Old 26-10-08, 05:24 PM   #20
4 on the curvy, you can get drilled ones and bolt them straight into the rivets.
Here's a wierd phenomenon... warped discs caused the reading to fluctuate at 100+mph.
Where's rest of pics then?
Curvy bits including rearsets and GSXR750 front end carsounds_dan For Sale - SV's and SV related items 14 09-01-09 01:23 PM
K6/7 GSXR750 width? Tim in Belgium Bikes - Talk & Issues 11 19-09-08 10:04 PM
srad gsxr750 front end wanted gruff Stuff Wanted 0 24-04-07 08:31 AM
GSXR750 SRAD Front End - Now Selling 21QUEST For Sale - SV's and SV related items 8 03-02-07 09:11 PM
EBC HH front brake pads for SV1000 or GSXR750 00-02 Razor For Sale - SV's and SV related items 5 14-07-06 07:09 PM
