Old 05-11-08, 01:12 PM   #11
AndyBrad
Default Re: My Bargain Viper Can.
easiest way is to lob through the whole thing with a chop saw. I have one in the shed if anyone wants to use it.
Grinder and stuff takes ages and you have to be precise, chop saw takes 30 seconds and cuts inner tube to exact length for you too
would you not risk crushing the can? (thinking of my carbon one here)
Old 05-11-08, 01:18 PM   #12
Why would a bench mounted saw crush it any more than grinder? Anyway if you want to do carbon one you can do it... I don't want to be getting a lungfull of carbon and epoxy. Yeugh.
Old 05-11-08, 01:21 PM   #13
jimmy-james
Originally Posted by Dappa D View Post
i love the sound of my viper, 25 bargain imo!!
when u say shorten...will u be just taking bit off or properly stubbying it??
Taking about 8 inches off the length i recon as i dont want it to be too loud and its just a tad long at present. Noise wise it sounds superb as it is just looks ridiculous!
Chop where you want to, and rivett all back up its pretty easy really. Mine really needs to be tidied up, it is a mess.
Do you need to cut the inner shorter than the outer or doesn't it matter?
Old 05-11-08, 01:24 PM   #14
AndyBrad
why would a bench mounted saw crush it any more than grinder? Anyway if you want to do carbon one you can do it... I don't want to be getting a lungfull of carbon and epoxy. Yeugh. :-p
got a mitre saw in the cellar i was thinking of using
Old 05-11-08, 01:30 PM   #15
Inner and outer same length.
Old 05-11-08, 01:34 PM   #16
jimmy-james
Thanks mate, it will make life easier
Old 05-11-08, 01:37 PM   #17
Dappa D
when u doin it jimmy-james?
pic if u can bud and how you found it hard/easy.
Old 05-11-08, 02:05 PM   #18
jimmy-james
I'm looking at doing it today and hopefully the polishing too so i will post before during and after. Thanks for all the suggestions everyone but unfortunatly i'm going to have to go the hacksaw route for this.
Old 05-11-08, 05:32 PM   #19
jimmy-james
The job so far…………………………
Marked with a pen and scored all the way round with the hacksaw blade.
Cut all the way through with the hacksaw making sure the blade stays in the scored area.
The two halves of the can.
Rivets drilled through on waste section and perforated centre cut away at the weld leaving a seat position for the centre on the good part.
After the cut.
A bit of swearing and hitting it with a rubber hammer and it all seated together nicely just the rivets to drill and pop now.
Just the cutting back to aluminium and polishing to do now and it should look ace!
I will post some pics when its all finished and back on the bike with a noise report, cant wait and all the evidence points to a loud system!
Old 05-11-08, 05:34 PM   #20
Polish it before rivets otherwise you won't be able to get the bits right next to the heads
Bargain PSP gavinsky23 Idle Banter 18 05-06-08 12:50 PM
Bargain Lozzo Track Days 8 18-04-08 11:05 PM
Bargain! Girth Idle Banter 9 21-11-07 07:05 PM
how much of a bargain....... maff Idle Banter 2 21-09-07 08:44 PM
Paging Viper, Viper come in please.. _Stretchie_ Idle Banter 10 10-08-07 01:43 PM
