#11 |
Cheers Chris.
I did look around the clutch cover when I cleaned it and ran it- appears to be clean and not the source of the leak- though I was a bit suspicious of the bolt that holds the clamp for the overflow pipe in place. No cracks on cover. However, I may remove it and check anyway. I shall have a look. |
#12 |
Oil leak update-
I degreased the engine today and cleaned the bike (in the occasional windy shower!). Took the socket set to the bolts on the clutch cover, and they've loosened- so clearly finger tight with a screwdriver handle on the socket is not enough. Tightened them more today, but I guess I'm gonna have to find a torque wrench that does 10nm, Haven't ridden it yet, but will see how I get on for the journey to work tomorrow... |
#13 |
I only had time to sort out the levers and remove my (knackered) heated grips and replace them with the old stock ones. I had a closer look at the area concerned though and it does look like I might of loosened those breather pipes. I'll give it a proper look next weekend.
#14 |
if it was a breather hose that had completely come away, I suspect you'd be loosing quite a bit of oil, has your level dropped much?
#15 |
After a journey to work and back today, no smelly burning oil on the collector pipe. Lovely.
Will monitor it for bolts coming loose again- and get the correct torque wrench in the near future. Assuming these bolts don't need threadlock... Good luck sorting yours Ceri. |
#16 |
Source of 125s | Alpinestarhero | Bikes - Talk & Issues | 10 | 31-07-08 12:22 PM |
Anyone know where I can source a CB500 rad? | Baph | Bikes - Talk & Issues | 3 | 04-07-08 08:25 PM |
Metal Detecting | rob13 | Idle Banter | 0 | 25-06-08 08:17 PM |
Not oil leak - Petrol leak - double "Bugger"...! | Potts | SV Talk, Tuning & Tweaking | 1 | 17-10-04 08:16 PM |
