Old 17-11-08, 09:33 AM   #11
petevtwin650
Default Re: Afterswapping the loom out.
Checked the wiring diagram and that mentioned loop is the sensor for the carb heaters.
Ah, that'll be me then. Took the sensor off to have the heaters working all the time when I thought the bad running might be down to carb icing.
Sorry 'bout that Grinch. Dunno why it should make the fan run all the time though.
Old 17-11-08, 09:36 AM   #12
Grinch
Oh this is bugging me, I keep just thinking about it and it so bloody annoying. Bike starts, all is fine... then bike fails to start, have no bike.
Old 17-11-08, 09:37 AM   #13
Grinch
I think its cus the connection for the carb heater-sensor and the temp-sensor on the rad is the same connector block and I got them mixed up.
Old 17-11-08, 10:44 AM   #14
Grinch
After a few PM's with Pete I have e-mailed Meta to check the components and fitting incase there was something I missed, it was Meta M357T alarm.
Old 17-11-08, 11:24 AM   #15
TSM
The Sick Man
TSM's Avatar
What did you miss? Forgot to remove alarm
Old 17-11-08, 11:35 AM   #16
Grinch
Well the alarm was not connected, but cut off so I re-soldered all the joints back together and sealed the loom back up.
I did leave a small cylindrical like resistor in the loom though, as it looked like a noise or surge suppressor. It was no bigger then my thumb so didn't think it was a immobiliser, and only had a single in-line connection. But now I'm wondering so thought I should check with Meta.
Old 17-11-08, 11:42 AM   #17
Grinch
Ah I think its a diode - Like the second one down -
Would this stop the supply as this is not what I thought a diode would do.
Old 17-11-08, 12:15 PM   #18
Grinch
Right, this diode should be fine as they are normally put in to stop power spikes from the indicators when the alarm flashes them. So it must be something I knocked when I put the bike together, so looks like I'm striping the bike apart.
Old 17-11-08, 12:28 PM   #19
454697819
have you checked the fuses and or the fuse that will have been wired into the alarm? I cannot recall wether they sit in the alram loom or on the bike loom...
Old 17-11-08, 12:39 PM   #20
Grinch
I un-wired the alarms fuse.
But good point, I didn't check all the fuses so I could have blown one, I had all the dash lights.
swapping battery with GSX600F Terence SV Talk, Tuning & Tweaking 3 10-07-07 09:33 PM
Swapping Radiators squirrel_hunter Bikes - Talk & Issues 9 13-05-07 02:38 PM
swapping batteries redeye321 SV Talk, Tuning & Tweaking 2 29-11-06 08:24 PM
Swapping headlight bulbs Jase22 SV Talk, Tuning & Tweaking 11 21-12-05 12:33 AM
Swapping the exhaust mysteryjimbo SV Talk, Tuning & Tweaking 2 06-10-04 10:48 PM
