Old 17-11-08, 05:11 PM   #11
petevtwin650
Default Re: speedo drive
Originally Posted by Ceri JC View Post
Is it actually plastic then? Mine was really brittle and felt a bit odd, almost like ceramics. I was only half joking when I likened it to 'fine china' in the other thread.
Just my take on the material Ceri JC. Can't imagine it's anything too exotic.
Old 17-11-08, 05:28 PM   #12
Dangerous Dave
Over 100,000 miles on the same speedo unit, never let me down once.
Old 17-11-08, 05:31 PM   #13
petevtwin650
That's it DD, once you are aware of how to replace it correctly it's a reliable set-up and much better than a gearbox take off, cos it does allow for gearing changes without making mental calculations every time you look at the speedo.
Old 17-11-08, 07:10 PM   #14
stevo_sv
mine has gone brittle and during the process of having the wheel off about 5times recently, 1 of the locating bits has snapped off.
since disturbing it the first time it now lets off a high pitch whine at low speed, very annoying.
checked it out 3 times now, seems to be rubbing inside so now needs replacing.
ebay it is
Old 18-11-08, 10:30 AM   #15
Ceri JC
As an aside, I just spoke to the parts dept. at my garage and the chap said he'd never had to order one before and was surprised when I said I'd heard of other people having this problem.
Old 18-11-08, 10:55 AM   #16
Dangerous Dave
It isn't a problem with the part, it is a problem with ham fisted numpty mechanics.
Old 18-11-08, 11:04 AM   #17
Ceri JC
Any particular trick to putting them back, other than making sure the teeth of the rotor fit properly into the relevant hole of the front wheel and that the axle is torqued up correctly?
Old 18-11-08, 11:06 AM   #18
Dangerous Dave
Thats it; allignment, fitment, and correct torque is the thing some dealer mechancis have problems with.
Old 18-11-08, 02:51 PM   #19
petevtwin650
Trick is I think is to have the"slidey" spacer nearly out of the right fork, locate the drive correctly and then slide the wheel over. Worked for me.
Old 18-11-08, 03:19 PM   #20
True, if a little extreme .
speedo drive baldwone Bikes - Talk & Issues 5 12-03-09 11:03 PM
Help! Need a speedo drive richwill68 Stuff Wanted 6 27-03-08 03:09 PM
Speedo drive goody SV Talk, Tuning & Tweaking 0 13-08-07 07:30 PM
speedo drive help johndo SV Talk, Tuning & Tweaking 8 30-04-07 08:46 AM
Speedo drive Normski Stuff Wanted 0 02-12-05 04:52 PM
