Old 18-11-08, 10:04 AM   #11
chris8886
chris8886's Avatar
Default Re: Another hagon spring question to those who use them.
i'm a similar weight to you and it made the world of difference to me. though now having had it for a while i'm starting to think i want better still!
AR08 to AR13-QUALITY!
Old 18-11-08, 10:12 AM   #12
Alpinestarhero
How easy is it do change the fork springs? I would love to put in hagon springs in my bike, but I don't want to annoy my dad by asking for his help or get in his way at his work (he always tells me to come down to his workplace to do stuff to my bike). I'm going to do the shock probably, kinda hoping my current rear shock can be used in the Honda VFR400 my dad is rebuilding
Old 18-11-08, 10:17 AM   #13
AFAIK, take the top cap off splurge out the oil, the spring follows, stick in new spring, put in new oil with recommended air gap...put on top cap...put back in bike away you go....but then YC makes it look easy
Old 18-11-08, 10:58 AM   #14
Dangerous Dave
Aye.
Don't forget to compress the forks several times to remove all the oil, same again on assembly to get all the oil in the right place before measuring the air gap.
Old 18-11-08, 11:25 AM   #15
Who was asking about rebound n compression and stuff?
There are no settings, if you get a hagon shock there is a damping adjuster but that works on both.
Oil weight mainly affects rebound on stock forks.
Front Spring Question DANINPLYMOUTH SV Talk, Tuning & Tweaking 5 19-03-09 05:27 PM
Hagon Shock Question pmapp SV Talk, Tuning & Tweaking 7 11-05-08 10:24 PM
Hagon fork springs question steveg SV Talk, Tuning & Tweaking 1 15-04-07 10:51 PM
Another question about rear spring preload. oldjack SV Talk, Tuning & Tweaking 2 25-07-06 08:09 AM
Fork spring question.... Junior SV Talk, Tuning & Tweaking 4 07-01-05 09:20 AM
