#11 |
Keep it simple, for USD forks what you need is the entire GSXR 750 SRAD (1996-1999) front end for a Curvy and for RWU forks the entire GSXR 600 SRAD (1996-2000) front end (bear in mind many GSXR parts are interchangeable between models)....
Yokes, Forks, Wheel, Spindle, Brake Discs, Brake Calipers, and the Fender. In addition you will need TL1000S clip-ons for the 750 forks as the GSXR ones are two low and the throttle cables will damage the fairings. To make it all work the simplest method is to buy a bearing from Twin Works Factory, this replaces the top bearing on the SV and allows for the bigger SRAD stem to pass through. The lower SV bearing can be retained as it is a shared part with the GSXR's. I have fitted 27 front ends to Curvy's in the past 9 years, and 4 have had steering lock alignment issues (which is a bit strange for a mass produced bike and parts). The simplest way to over come this, and the best if you want to return to the SV front end in the future, is to file off 1mm from the SRAD's right hand side steering lock tab. This will allow the SV's handle bars to lock and cause no permanent damage to the bikes frame or ignition barrel. SV800S Another method to mount the yokes, without the TWF bearing is a little more time consuming. You need an SV steering stem for the SRAD bottom yoke, however it is a smaller diameter than the SRAD's so you will have to braze some metal on and then mill it down to the correct size. A shim (spacer) is also required for the top yoke as the SV steering stem is a smaller diameter up there too. The advantages of this method is that the bike retains all its original headrace bearings, thus making them easier and quicker to get hold of. The one problem you will be left with, whether you go USD or RWU is the speedo. The SV650 runs it speedo off of the front wheel and the SRAD wheel has no location for it and the SRAD spindle has no space and is to large a diameter to except the speedo unit. There are three option to take, one is to run with no speedo, another is to use a Hall Effect sensor (Northwind and Yorkie Chris are your experts here ![]() The above USD fork option is only applicable to Curvy SV's (1999-2002). Pointy's are far simpler, most of the 2001 onwards GSXR front ends just bolts on using the existing bearings. Last edited by Dangerous Dave; 15-12-08 at 08:36 PM. Reason: Missing Pictures Added |
#12 |
Apologies for digging up such an old thread, but reckon it wasn't worth creating a new one.
I'm starting on my curvy SRAD SWAP and I have a few questions. I bought TWF's bearing (incl. modifying the steering head ext. the notches) and the SRAD dust cover like they advise. 1. Below is a shot from the curvy steering stem. What parts can I reuse except of course the triples and the steering stem itself? ![]() 2. "file off 1mm from the SRAD's right hand side steering lock tab" If you look at the shot below, is this is what is meant? ![]()
'02 (Curvy), yellow, Sport Smart, mods: progressive fork springs, '03-04 ZX-6RR rear shock, Li-ion battery, Leovince slip-on, Powerbronze airflow double bubble, flush front indicators, bike-it integrated LED rear. SRAD front end conversion on going. |
#13 | |
EDIT : With regards to the lock-stop, you've highlighted the left-hand side there but that's the idea. I'd mount it up first and see how you get on though. IIRC not everyone has needed to file the lock-stop. Last edited by TamSV; 06-05-11 at 01:32 PM. |
#14 | |
#15 |
Mine went straight in and steering lock worked without filing lockstop, I have seen another that didn't.
front end swap | zsv650 | SV Talk, Tuning & Tweaking | 7 | 22-01-09 03:04 PM |
GSXR Front End Swap | Kemp10 | SV Talk, Tuning & Tweaking | 43 | 02-12-08 04:47 PM |
yes, another gsxr front end swap, done | Bibio | SV Talk, Tuning & Tweaking | 25 | 16-09-08 04:07 PM |
GSXR front end swap - front tyre profile. | Khewett | SV Talk, Tuning & Tweaking | 12 | 11-05-06 11:24 AM |
Do I have everything now for a GSXR front end swap?? | Khewett | SV Talk, Tuning & Tweaking | 6 | 28-04-06 02:15 PM |
