Old 02-01-09, 02:40 PM   #11
Magnum
Default Re: Ground Anchors & Chain
Originally Posted by arcdef View Post
click here to see how much being top rated means!!!
My hardcore lock is advertised as being bolt crop proof. Whats that black thing in the pic?
I suppose if you want to fork out that much money then fair enough. I may have considered it if i hadn't already bought the hardcore, which i'm still happy with anyway.
Old 02-01-09, 02:43 PM   #12
Dappa D
+1 almax
forget magaxine ratings IMO, dont mean anything, I wouldnt use anything on the market right now apart from almax
the clicky above pretty much sums this up, if u can find the video aswell of various chains being cropped..have a look, is very interesting
Old 02-01-09, 02:46 PM   #13
Dappa D
bolt crop proof? me thinks not, are you happy with it because your bike thus far has not been nicked?
im happy with mine because it bears the slight scars where some little fecker has clearly had a pop at it and gave up...this is why im happy with mine.
Old 02-01-09, 02:56 PM   #14
arcdef
the black thing is a portable hydraulic cropper which it says all the the chains were cropped in under 12 seconds with it
Old 02-01-09, 03:01 PM   #15
Sort of thing Firemen would use to chop up a car
Old 02-01-09, 03:38 PM   #16
Dangerous Dave
What ever chain or anchor you get they will not be 100% affective, anything can be broken and a determined thief given enough time will cut through a chain/lock/anchor.
Originally Posted by sauluk View Post
Where's good to wrap the chain on the SV then?
Depends on the actual anchor you get, some are designed to dug down into concrete and other bolt onto a surface (floor or wall).
And should ground anchors be used on the wall or ground, not sure I could get it in the wall but have a concrete floor in the bike store.
Best to put the chain through the rear wheel and swingarm if possible, try not to let the chain be slack as it is at these points that thieves have more access to use stronger tools.
Old 02-01-09, 05:17 PM   #17
ogden
ogden's Avatar
I use an RGV250 as an anchor for my GSXR, and a GSXR as an anchor for my RGV.
ogden
S1000XR | 990SMT | YZF-R6 #7
ogden is offline   Reply With Quote
Old 04-01-09, 01:54 PM   #18
sauluk
This may sound dull but do I need a 0.7m or 1.5m chain to lock up via the back wheel/swingarm?
Old 04-01-09, 02:12 PM   #19
ogden
ogden's Avatar
Depends what you're locking it to. 0.7m really is very small - think of the circumference of the wheel and tyre and see how much you have left.
ogden
Old 04-01-09, 02:39 PM   #20
Dave20046
Dave20046's Avatar
As said almax chain is a must (if funds allow), but your padlocks also a weak point almax recommend closed shackle squires I think.
Where can you loop it round the swingarm that it won't slip off when the wheel's removed dd?
I'd floormount the anchor and then park the bike over the anchor so they can't access it easily and have little room to work.
Think your ground anchor and chain keeps the SV safe? Goonermadness Bikes - Talk & Issues 39 25-01-08 10:57 AM
Ground Anchors and what to screw them to... amnesia Bikes - Talk & Issues 9 16-10-06 01:25 PM
Ground Anchors Jase22 Bikes - Talk & Issues 13 20-06-06 10:24 PM
Ground Anchors fizzwheel Bikes - Talk & Issues 1 20-02-06 11:01 AM
Ground anchors wyrdness Bikes - Talk & Issues 8 06-04-05 01:39 PM
