#11 |
#12 | ||
If the plug looks like it's been detonated, or the core has melted, that's a good sign of lean mixture. But post back here with the state of your plugs (and photo if possible). This will help steer everyone, as your problems could be lean fuel mix, or it could be electrical sensors etc. |
#13 |
You can have a mix lean enough to feel absolutely naff without obvious signs of melting the plug. Depends where it's lean. but, post a pic of the plugs anyway.
#14 |
I'll post a pic of the plugs on Friday.
Risked my commute back into work this morning. Bike ran sweet. Idling was spot on, not one thing out of place. The only difference between the two journeys is last night I was hitting 10-11k rpm, sometimes for periods of 3-4 minutes, this morning I didn't go over 6k rpm, sitting at 80 most of the way. I want to diagnose this even if the problem has gone away, just for closure. I'm sure plenty of people with FI SVs will start getting these problems now they're getting a bit older, higher mileage. |
#15 | |
#16 |
Think it was the air filter, half expected to find a dead bird in there. Installed new filter, bit shocked to find out I should be on my third one by now. Noticed quite a number of threads on here regarding the mayo caused by condensation, whilst I was in the air box I took a gander at the crank case filter, the bottom of this thing looked like someone had squirted mayo all over it, pure mess, initial thoughts were head gasket. I have the same symptoms like many of you on here. Sight glass milked up, mayo in the oil cap. I never do short journeys, always 50 miles minimum. Checked coolant level, hasn't dropped. And doesn't look like the oil level is filling either. Must be just condensation.
#17 | |
#18 |
Coil
