Old 21-02-09, 06:56 PM   #11
Jester666
Default Re: Bespoke Throttle Cables
Surely the only difference is in the length. The S and the N have the same frame, forks, carbs, tank yaadee yaadee. The main difference is the yokes and bars, no?
I mean a cable's a cable isn't it. Bit of wire with nipples (snigger) at each end.
Old 21-02-09, 07:01 PM   #12
Didn't look like it on the parts fiche. Looked completely different. He also said I'd need a new switchgear for some reason.
and don't call me Shirley
Old 22-02-09, 07:16 PM   #13
tactcom7
Cheers for letting me know mate, looks like i'll have to make some up myself *gulp*
Old 22-02-09, 07:49 PM   #14
Jester is right
Why don't you have a look on the parts fiche here for the naked & the faired version.
http://www.powersportspro.com/pages/.../1/Suzuki.aspx
The part numbers for the cables are going to be different, but the cable ends are going to be identical.
All motor manufacturers are going to use common parts where they can, so throttle twist grips are going to be the same, carbs are the same.
Some of the naked's had a different master cyclinder to the faired, because of the faired clip on postion.
New switch gear? He's havin a laugh.
Just out of interest early GSXR's have the same size bottom & top steering bearings. The small needle bearings in the shock linkage pivot on the swing arm have the same part number as a Hayabusa
Old 22-02-09, 07:56 PM   #15
I already have. The cable ends are the same but that's about it
Old 22-02-09, 08:04 PM   #16
I saw longer cables for SV's on EBAY, have a look there.
Seller was selling the high rise bar kits for various bikes, including SV.
He was selling longer cables as seperate items
Clutch cables/Throttle cables Curvy 21QUEST For Sale - SV's and SV related items 0 05-08-08 08:45 AM
loose throttle cables??? sfstu SV Talk, Tuning & Tweaking 4 01-06-07 06:45 PM
Someone cut my throttle cables! SVeeedy Gonzales Bikes - Talk & Issues 42 29-03-07 12:16 PM
Throttle Cables ugp Stuff Wanted 7 30-12-06 12:15 PM
WANTED!! 1st Gen SVS throttle cables zunkus Stuff Wanted 5 19-03-06 08:10 PM
