#11 | |
I have the sculpted seat, you can buy an original Suzuki one for £35, cheaper than having your seat scooped out and shaped and you get 2 seats that way too.
<((((((((((((((((◕‿◕) The Woozle woz ere (◕‿◕)))))))))))))))> Black K4 Pointy named Zuky, OEM belly pan, OEM hugger, OEM cowl, R&G bungs, akrapovic system, tinted double bubble Fabbri screen, tail tidy, scottoiler, alarm, datatagged, lowered seat for short ass rider named Shell. ![]() RIP PC David Rathband sad day 29/2/2012 |
#12 |
dose any one have a lower seat for a curvey they want to sell i cant find a seat any where or cant find a link from suzuki for a genuine one ,and do you lower the front forks the same on a curvey as you would an a pointy ??? 10 mm if i buy a set of 25/30 mm bones to lower the back im a shorty as well but on the 13 st side (wrong side )of being light ey
![]() 2002 sv 650 |
#13 |
I got the genuine lowered seat from my local dealer - £32.
Its not a lot lower, but definately makes a difference. It also makes it a bit less comfortable, but you soon get used to it. I wouldn't want any more foam taken out of it.... As for lowering the front, you could see from the marks left on the fork stantions on mine that they had compressed pretty close to the clamp, ie if you dropped them there is a chance contact would be made. If you're thinking of doing it I'd strap a zip tie around a forks leg, get her to ride for a couple of weeks then see how far up it gets pushed, before you do anything. Try the seat first. Makes going backwards a lot easier as well! |
#14 |
I'm the guy that's just bought the SV of 'Spokey', which has the sculptured seat on. I'll happily swap it for the original if you like.
#15 |
curvey or pointy ????
![]() 2002 sv 650 |
#16 | |
It will be a suck it and see figure, but I doubt it'll go further than ~15mm.
#17 |
Lowering my SV650 | bikebunny | SV Talk, Tuning & Tweaking | 2 | 04-03-09 05:36 PM |
Lowering An SV650 For A Shortie | JUICY LUCY | Bikes - Talk & Issues | 30 | 22-06-06 12:19 PM |
Lowering a SV650? | Beth | SV Talk, Tuning & Tweaking | 8 | 20-03-06 11:20 AM |
Lowering SV650 | Russ | SV Talk, Tuning & Tweaking | 3 | 29-11-05 07:39 PM |
Lowering an SVS... | Aaron_T | SV Talk, Tuning & Tweaking | 11 | 08-08-05 06:03 PM |
