Old 22-02-09, 08:15 AM   #11
muffles
Default Re: Warm up first?
No one here has an oil temp gauge as well do they? If you've only got one temp reading it's a 99% chance it'll be your coolant not your oil. Oil takes a lot longer than coolant to warm up...and is the important one...
Old 22-02-09, 07:13 PM   #12
Biker Biggles
Biker Biggles's Avatar
Originally Posted by Stu View Post
Thanks
I get fully ready before starting, then pull away once settled in 5 secs then switch off choke as soon as I'm riding.
Try not to use many revs until it's warm is the only concession I make
I also ride off as soon as the bike will go without stalling.
Old 22-02-09, 07:18 PM   #13
Larry
I let the bike run until it idles with no choke, then I ride off gently for 5 mins or so before raising the revs a bit.
Old 22-02-09, 07:21 PM   #14
ThEGr33k
Warm it up by starting leaving for 30 seconds then holding it at full throttle on the rev limiter for 32.3 seconds... All warm.
Ok no that's bad... It would be warm, but also ever so slightly knackered
Start and ride tbh.
Old 22-02-09, 07:45 PM   #15
BBadger
start it, ride it slow and easy till it reaches 50 odd and riding that only takes a min or two so youve got nothing to worry about.
Old 22-02-09, 10:19 PM   #16
thefallenangel
was told by someone i'd trust with engines "Any engine half revs until up to temperature is fine". Safe to say his Audi A6 is at 180,000 miles and hasn't missed a beat although his wing mirror is broken.
Old 22-02-09, 10:47 PM   #17
suzsv650
2 Stoke defo needs warming and for a long time....
SV not so much
I usually leave the the R6 about 1-2 mins then ride crarefully
Old 22-02-09, 11:04 PM   #18
SVGrandad
SVGrandad's Avatar
Engines warm up faster with a bit of load on them, so fire them up and run them gently for the first few miles. Once hot, ride normally. Oil needs to get hot to boil off condensation etc, so riding too gently for the whole journey is not good for it either, but I dont suppose that applies to anyone on this forum!
SV1000S K4, Hugger, Scottoiler. Lowers
SVGrandad is offline   Reply With Quote
Old 22-02-09, 11:10 PM   #19
Miles
Originally Posted by embee View Post
You really don't do it any favours by leaving it idling for prolonged periods from a cold start, it's contaminating the oil film on the cylinder bores with fuel and condensation, which reduces the service life of the oil and increases wear rates on the rings and bores. Also idle is about the worst condition for valve train wear.
Start it, let it settle for a short time for the afterstart enrichment to ramp down or just long enough to get the choke off, typically no more than 30sec is needed, then ride off gently.
As said, gradually ease the revs and load up while it warms up fully before using high power/revs.
That's what I've always been led to believe.
At idle it takes longer to warm up and oil pressure will also be lower.
As long as you take it easy for the first few miles, and dont show it the redline until the oil is properly warm then I shouldn't worry.
Old 22-02-09, 11:12 PM   #20
xXBADGERXx
Thanks
I thought you had a pointy Stu ? Auto-Choke on them or have you rigged something up ?
Throughout the ownership of my bike I have done this :
Put jacket and trousers and boots on , go outside and start bike , unlock chain , zip jacket and do lid up , throw gloves on , back it out of driveway and then pull away . No more than 2 minutes tops to do all that . Run the bike for about a mile to the A55 at no more than 5k revs and then when I hit the A55 I don`t go past 7k revs . Once I am onto the fast bit of the road the bike is nicely warmed up and I am happy to give her a bit of a Toot on the way to work .
Warm grips jumjum_0214 SV Talk, Tuning & Tweaking 23 08-12-08 08:27 PM
Oil leak when warm AndyBrad SV Talk, Tuning & Tweaking 3 18-08-08 05:19 PM
To warm up or not to warm up.... DanAbnormal Bikes - Talk & Issues 21 16-08-06 04:30 PM
tyre warm up v's engine warm up? twotime SV Talk, Tuning & Tweaking 25 14-07-05 11:06 PM
Warm up BenScott SV Talk, Tuning & Tweaking 20 11-05-05 04:36 PM
