#11 | |
![]() just about manage to fit the main unit under my SV seat next to fuse box. Experimenting with the aerial position at the moment, got it strapped down to the front brake reservoir as its high and exposed. but still get flashing green light in built up area (central london) ![]() Last edited by Lucas; 16-03-09 at 11:29 AM. |
#12 |
The '08 Z750 ABS has so little space unserseat that I have had to sacrifice the tool-kit to fit the Inforad.
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) Last edited by Sid Squid; 16-03-09 at 11:35 AM. Reason: Dave, I've told you your keyboard is goosed. |
#13 |
#14 | |
Cheers Mark.
#15 |
Nice one Lucas. I've got two in the post!
Incidentally can one subscribed dongley doo dah be used in two seperate units? |
#16 |
Yes, the Inforad unit itself is the separate piece held by two thumbscrews, the bit on the bike is just a connector, you could just use one of the actual Inforad units on two bikes.
You can't update two units on one subscription though - the unit is individually recognised by the update software.
#17 |
#18 |
I see...
I tried but couldn't make it work, (it must be said computers are definitely not my area of expertise though), perhaps you might explain how you managed this.
#19 |
umm at work so difficult to remember. When you update, it saves the update in a directory - went to that directory, renamed the file to March09 or whatever. Then put second device in, selected the import file option and picked it.
Bit sketchy, its from memory. |
#20 |
Must try this out and see.........
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
Inforad siren modification | tigersaw | SV Talk, Tuning & Tweaking | 37 | 02-02-10 10:38 AM |
Inforad fitting advice. | Spiderman | Soho Massive | 41 | 13-06-09 05:00 PM |
Inforad | rictus01 | Bikes - Talk & Issues | 3 | 06-04-09 06:06 PM |
Anyone bought an Inforad recently? | Bear | Soho Massive | 0 | 03-04-09 03:46 PM |
Inforad Bargain | Davies | Bikes - Talk & Issues | 0 | 05-03-09 04:10 PM |
