Old 23-03-09, 12:27 PM   #11
Stig
Default Re: I have messed up cleaning my calipers.
Originally Posted by flymo View Post
nah, this method works surprisingly well. Obviously not a single fold of the material. With a good wad of t-shirt (other clothing garments are available...) and a firm grip with the mole grips you can rotate the pistons as you pull them, works a treat. Used this approach loads of times with no damage.
Quite possibly so. But to just state use a T-shirt is not a very good explanation. I can envisage plenty of less knowledgeable folk killing pistons by this explanation. I would personally use a nice thick chunk of card. Mole grips flat edges gripping a rounded surface. A recipe for damage to occur.
Old 23-03-09, 12:29 PM   #12
plowsie
My bad.
Old 23-03-09, 01:49 PM   #13
jambo
jambo's Avatar
Stu, As I'm sure you're aware the 6 pot Tokicos fitted to the ZX6R (I'm assuming this is the bike we're talking about) are made in 2 halves. There should be 4x 6mm hex headed bolts holding them together. Now Ideally you'd loosen these while the caliper was mounted to the fork, but you won't be able to do that easily now as the disc won't go back in.
Carefully secure the caliper so as not to damage it, undo the 4 bolts holding it together. This gives you access to all your pistons. When you've reassembled and pushed the pistons back in, put the 2 caliper halves back together and torque them back up.
Jambo
Edit:Clearly after doing this the caliper will be empty of fluid and you'll need to bleed it, but as you've already had a piston come partly out I figured you were down this road anyway.
Old 23-03-09, 07:48 PM   #14
Razor
Got red rubber grease? Essential for re-assembly, grease the seals before and lessen the change of damaging one of them.
Old 23-03-09, 11:29 PM   #15
Stu
Trinity
Stu's Avatar
Originally Posted by punyXpress View Post
Yep So when he pushes that one back, there's room to take the one he was shifting right out. I think, but that's a dangerous thing for me to do.
Yes that's possibly a good plan - If I had one
Jambo
Yup the caliper is empty so that's fine. But I don't understand how splitting the caliper will miraculously give me access to the pistons won't I be faced with the old mole grip scenario for the remaining 5 pistons to get them out still? I can still attach the caliper to the bike with one bolt as I did that to get the brake line off
Yeah got that thanks
Ohh Almost forgot to say, many thanks to all posters especially to all those who refrained from saying have you done a search
Old 23-03-09, 11:39 PM   #16
Razor
and nobody said RTFM either
Old 24-03-09, 10:50 AM   #17
Bear
It won't, but from the sounds of things you have popped one out too far and it's jammed against it's opposite number. Splitting the caliper will allow you to get that one back in, then pump the others out as normal.
By the way, have you done a search...
Old 24-03-09, 11:55 AM   #18
monkey
Here's a possible slight derail but relevant to said calipers.
Us there enough space to pump all 6 out enough to be able to Remove them?
Old 24-03-09, 12:35 PM   #19
Bear
If you pump one side out at a time you can pull them all the way out. It's not a bad idea to do this regularly as they get covered in brake dust and crystalised brake fluid which stops them sliding in and out properly, give 'em a clean up and re fit them and binding calipers will be a fing of da past...
dumb cleaning question - brake calipers skyline SV Talk, Tuning & Tweaking 6 27-10-08 01:21 PM
my messed up garage yanto Photos 7 18-06-08 06:52 PM
Cleaning Calipers squirrel_hunter SV Talk, Tuning & Tweaking 14 18-12-07 08:02 AM
MSN Messed up? SoulKiss Idle Banter 32 18-11-06 11:14 AM
cleaning calipers -again! jim@55 SV Talk, Tuning & Tweaking 1 11-03-06 03:25 PM
