Old 24-03-09, 06:22 PM   #11
arcdef
Default Re: Whats wrong now!!!!!
KK ill get them out in the morning if it still isn't playing ball. What should i be looking for (obviously colour and spark) as a general reason for it stopping so suddenly??
Old 24-03-09, 06:29 PM   #12
maclovin
have you checked the yellow/black wire on the coils ? under tank had the same problem myself . if rev counter ok will be right hand on as you sit on bike , if rev counter not working will be on the left . hope this makes some sense
Old 24-03-09, 08:02 PM   #13
arcdef
Not quite sure what you mean by that?? Are the wires under the air box?? am i looking for wear through the wires or where they connect?
Old 24-03-09, 08:09 PM   #14
You got plenty juice in it?
Old 24-03-09, 08:10 PM   #15
Hmmm maybe a big air leak, airbox popped loose, carb balance port cap split etc.
Old 24-03-09, 08:10 PM   #16
arcdef
The light had just started flashing but not gone solid, dont tell me its because it was getting low??
Old 24-03-09, 08:10 PM   #17
Nah.
Old 24-03-09, 08:14 PM   #18
arcdef
Ill have a look for an air leak also, is the port cap under the carbs?
Old 24-03-09, 08:29 PM   #19
Yes
Old 24-03-09, 08:52 PM   #20
punyXpress
punyXpress's Avatar
Did you need choke after all that pampering?
If so, did it return ( with or without your help )
Now: Street Triple R
rough running ? mikey devon SV Talk, Tuning & Tweaking 11 21-03-09 12:07 AM
Running rough when hot svdemon SV Talk, Tuning & Tweaking 3 13-08-08 07:44 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Running Rough? mike_b SV Talk, Tuning & Tweaking 3 20-12-06 11:38 PM
Rough running after several months off :( Gasman SV Talk, Tuning & Tweaking 3 23-12-05 07:17 AM
