Old 01-04-09, 10:42 PM   #11
Nicky S
Nicky S's Avatar
Default Re: Louder! (without exhaust change)
Originally Posted by Spikenipple View Post
Remove the snorkel from the front of the airbox, then fit raisers to the two front tank bolts. Gives it a nice growl on the throttle above 5000rpm.
dose it do anything except make the bike sound diffrent ??
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 01-04-09, 11:18 PM   #12
Stu
Trinity
Stu's Avatar
Search svrider.com for mufflerectomy. You drill holes inbetween the exhaust and the baffle. you can carry on to remove the baffle.
I dithe1st part it helped a bit
Old 02-04-09, 08:19 AM   #13
STRAMASHER
STRAMASHER's Avatar
Remove the rubber snorkel from the air box and the induction noise will drown out a race pipe (well my remus anyway) on big throttle openings. Lovely.
Old 02-04-09, 08:25 AM   #14
Yeah freer flow as well as lots of induction noise. Works a treat on the curvy as well but some adjustments will be needed to the fuelling.
Old 02-04-09, 08:57 AM   #15
Nicky S
Nicky S's Avatar
kk what has to be taken off the airbox or if you do this do u get rid of the airbox and use ... umm dont know what they are called but 2 like cone fillters ?
Old 02-04-09, 09:49 AM   #16
You could use pod filters but the tuning becomes difficult.
Remove the snorkel from the airbox. Buy some bigger main jets..
Old 02-04-09, 10:50 AM   #17
Nicky S
Nicky S's Avatar
snorkel ??? is that just on the s model ??
Old 02-04-09, 11:14 AM   #18
Alpinestarhero
Originally Posted by Dan View Post
Top Tip:
Save pounds on expensive performance modifications. To instantly feel like your bike is faster, simply make loud 'Broooooooommmmm' and 'Neeeeeeowww' noises in your helmet whilst riding.
it so definatly works
and if you make throttle blipping noises at traffic lights, it can save you fuel
Old 02-04-09, 11:25 AM   #19
Viney
Nicky, on the Curvey model the is no sonorkel, thats for the pointy models only. However, there have been things where you cut out the center, or drill holes in the filter itself., but as said, it leads to a few nighmares on fueling, and really isnt work it (Been there done it got the tshirt) and is a lot of hassle for no real gain. If you do want to do it, seek out a dynojet kit/larger jets, and i believe a BMC RaceRS filter. If you want you bike to feel a little perkier, the R6 throttle mod, and either upping the teeth on the rear or dropping 1 on the fornt sprocket will amke it a little more spritley.
Old 02-04-09, 07:28 PM   #20
Nobbylad
Nobbylad's Avatar
I thought all CCC cans had removable baffles?
Originally Posted by suzsv650 View Post
obviously a rivet is a weld. Take the baffle out!, moron
WTF?!
I have to change exhaust bris SV Talk, Tuning & Tweaking 19 08-04-09 08:12 PM
Wanted - louder exhaust for curvy phuk72 Stuff Wanted 4 09-12-08 10:06 AM
Exhaust change sv650sfan SV Talk, Tuning & Tweaking 5 12-07-07 07:00 AM
Cam louder then exhaust..VERY loud! johnlennon1 SV Talk, Tuning & Tweaking 2 10-05-06 10:20 AM
louder original exhaust? fabio SV Talk, Tuning & Tweaking 11 18-09-04 09:46 AM
