Old 01-05-09, 12:09 PM   #11
SoulKiss
SoulKiss's Avatar
Default Re: Idle Speed is strange after a spirited ride?
Shouldnt this be in Idle Banter
Anyways - good to hear still under warranty - hope it gets sorted out.
You COULD risk bringing it to Soho where some mechanically minded souls MAY be this evening
Old 01-05-09, 12:27 PM   #12
Any fault code/FI light?
Old 01-05-09, 07:46 PM   #13
krhall
Hadn't thought of that, needed to get home to take the little darlings Judo.
No absolutely nothing shown.
Old 01-05-09, 07:55 PM   #14
IAC valve is a culprit if fitted. Probably best to check all the sensors when it does go wrong and see what the ECU is actually saying, but I've got no idea how much data you can get out of it. So probably best it's gone in under warranty.
Now if you had carbs on it...
Old 01-05-09, 07:59 PM   #15
krhall
On a bright note I have asked for a new blade as a courtesy bike......hope it doesn't prove too nice.
Wonder if it is a common fault?
Tks YC
Old 01-05-09, 10:06 PM   #16
Holdup
If i remember i will ask about it 2moro at work, but its good its still under warranty
Out of intrest where you taking it to?
Old 02-05-09, 08:05 AM   #17
krhall
It's going to 21st Moto (Swanley) as they are my local Honda dealer.
Old 13-05-09, 01:20 PM   #18
krhall
Right - Dropped her off last Tuesday evening for a Weds look at it by them.
No courtesy bike available, so I struggled by car for the rest of the week, called them Friday and they hadn't looked at it so I arranged a courtesy bike pick-up for Saturday, which suited me.
Called them again earlier to find out what was going on as I was starting to worry it was something bad, just got the call back to say they couldn't find the fault and that just to be sure they had reset the ECU setting, which were already at factory default, so that will just be a small charge of £32 something.
Erm, no "it's under warranty mate".
Eventually came back to me to tell me that if no fault is found it is then chargeable, but on this occasion they will waive the charge and I can pick the bike up whenever I want. It could just be bad fuel or something?
What do the mighty all-knowing org think?
Old 13-05-09, 02:34 PM   #19
Holdup
To right they should wave the charge, id be miffed if it was booked for wed and not looked at, you can only try and see did they test ride it?
Old 13-05-09, 02:44 PM   #20
krhall
Yeah - I bet the apprentice has been test riding it all f-ing weekend!
Idle speed? weecorey SV Talk, Tuning & Tweaking 4 07-02-09 09:30 PM
Linux/Internet Speed Question...Strange! poisonidea Idle Banter 3 21-08-08 05:47 PM
idle speed ? svdaz SV Talk, Tuning & Tweaking 11 29-04-08 05:32 PM
HOW to change idle speed andygib SV Talk, Tuning & Tweaking 4 31-01-07 04:09 PM
Idle Speed stevelondon1979 SV Talk, Tuning & Tweaking 8 23-03-05 09:10 PM
