Closed Thread
Old 20-05-09, 04:32 PM   #11
Default Re: Nitron race shock
Originally Posted by injury_ian View Post
Negative dear fellow,
I had the same concerns, so phoned them up had a little chat.
Nitron claim the damping is the same regardless, (it is 30 click adjustable comp & rebound).
to quote Nitron "normal setup is 10clicks out from full hard, but adjust to taste"
I'd hope they know thier onions.
OK I was going on the idea that a harder spring will rebound harder thus needing more damping to keep it under control when you get a rapid extension. But if that's what they reckon then fair do's.
yorkie_chris is offline
Old 20-05-09, 04:38 PM   #12
svdemon
Thats exactly what you are doing when you turn the damping up, harder spring = turn damping up to suit.
Old 20-05-09, 04:40 PM   #13
This I know. But adjusters only affect the low speed bleed, high speed is affected by loads of stuff, preload of shim stack, shim stiffness, oil weight, nitrogen pressure, shape of piston.
Old 20-05-09, 05:24 PM   #14
svdemon
I'm pretty sure they're adjustable for high and low speed compression and rebound/
Old 21-05-09, 10:44 AM   #15
Geoffrey
I apologise for this not being particularly connected to the sale.
But you really need to change the valving of a shock to suit the spring.
i would agree with you on that one yorkie_chris, you do not only change springs to suit different weights.
Old 25-05-09, 07:23 PM   #16
mike_red2uk
hi is the shock still forsale ????
mike
Old 26-05-09, 06:55 AM   #17
gazza
Its been sold.
Closed Thread
Nitron Shock. Rich SV Talk, Tuning & Tweaking 36 04-08-10 08:56 AM
My Nitron Shock & HeliBars on E-bay Jackie_Black For Sale - SV's and SV related items 1 31-01-09 01:52 PM
Nitron Race shock...Top of the range 21QUEST For Sale - SV's and SV related items 0 05-08-08 12:01 PM
