Old 07-07-09, 10:58 AM   #11
flymo
flymo's Avatar
Default Re: Engine Swap
Originally Posted by Ginger 1 View Post
Quick question do i need some special tools? or will a hammer and socket set do
Yeah basic tools. Also not a bad idea to have a manual and a torque wrench handy if you want to do it properly.
Old 07-07-09, 11:05 AM   #12
Castellated sockets for the adjuster bolts too.
Old 07-07-09, 11:12 AM   #13
lazymanc
It went ok, although I do seem to have a small coolant leak I need to track down, every time I go back to the bike there's a small drip hanging on the waterpump.
Other than that it's running ok, although I haven't tried going up through the gearbox yet, only neutral.
I would definitely have a torque wrench (10-100lb/ft) handy, as some of the torques for the engine mountings are quite high. They also have the castle-type locknuts around the bolt spacers, so you'll need a peg-spanner or some of these:
Be methodical - have some trays ready for everything you take off and label them. I only did it with a few bits and it's a pain in the **** trying to remember where it all went. Taking pictures as you go would also be a help for routing pipes / cables, this was something else I struggled with but you can mostly work it out from the natural kinks that have developed and by the connections as they're mostly unique.
I would also say a haynes or service manual is a must, just for piece of mind, but you might be more maverick than I am
lazymanc is offline   Reply With Quote
Old 07-07-09, 11:18 AM   #14
lazymanc
Originally Posted by flymo View Post
For what its worth, I would whip the spark plugs out of the new engine and turn it over gently with a socket on the end of the crankshaft. If everything turns nice and smooth slap it together and fire it up.
Yep, with the covers off and the plugs out it was turning over smoothly from the flywheel.
Once I had it back in the frame with oil and coolant in it and all the electrics wired up, I gave it a good couple of 10 sec bursts off the starter motor without any fuel connected to get the oil well distributed inside after it had been sat dry for so long. This actually dropped the oil level a fair bit from the first fill, so I kept topping it back up until it consistantly returned to the same level in the spy glass.
Old 07-07-09, 11:26 AM   #15
flymo
flymo's Avatar
You need to be careful doing that. You should allow time for the oil to settle back into the sump before checking the level again. You'll probably find there is too much oil in there now.
edit....or maybe thats what you were already doing....might have misunderstood you there.
Old 07-07-09, 11:39 AM   #16
If its coming out of the water pump, theres a funny shaped rubber gasket in there, it may have perished or something. Make sure hose clamps are in good condition too. Squeezing the pipes will tell you this.
When my engine was swapped out, we noticed that the clamps had corroded so small drips were present, as it wasn't clamping anymore, you couldn't tighten it. I wasn't paying Suzuki prices...theres still a bodge jubilee clamp on the hose.
Also Im Indoors mentioned has someone ommitted to put the copper washer back in the drain plug of the water pump, when they drained the system?
Old 07-07-09, 11:54 AM   #17
lazymanc
I think it might be the funny shaped seal between the two halves of the water pump as I didn't take it apart to check it . The 2 o-rings between the waterpump and the clutch cover were in good nick however and I put some loctite silicone sealant around them for good measure so i'd be surprised if it's those. The washer is on the coolant drain plug but it's the old one so maybe I should've replaced it.
It's due a valve clearance service and MOT as soon as it's ridable anyway so as long as it'll get me to a garage I think i'll let them worry about it. It might seem weird after doing a full engine swap that I want to pay for a normal service but I'd prefer to have someone professional check over my handywork before I start riding it in any sort of anger.
Old 07-07-09, 12:02 PM   #18
lazymanc
Yeah sorry, I'll explain:
1. Starting from a completely dry engine, I filled the oil to half way between the low and full markers in the spy glass.
2. I then turned the engine over with the starter motor for 10 secs
3. Left it a minute or two for the oil level to settle back down
4. Topped up the oil back to half-way.
5. Repeated 2-3-4 until the oil was staying settled at half way mark
6. Connected up the fuel tank, put in a bit of fresh fuel, started the engine.
7. Let it run on idle, checking for weird noises, let it get to 80c to check for temp related leaks.
8. Gave it a bit of throttle just for fun
9. Turned it off, left it 5-10 mins, checked the oil, topped it up to just under the F line.
I also topped up the coolant resevoir at this point, so I think that should cover everything fluid wise.
Old 25-04-11, 11:15 AM   #19
all the gear
Hello all, firstly I’m new to the SV650 and forum, and would appreciate some advice .I have an SV k4 model with a thrown con rod engine number p507- 134195 it’s injection as you probably know .I would like to know which engines are interchangeable with this bike. I have seen a low mileage v/strom one for sale but don’t really know if it will fit without any power loss
ie is the power output from mapping or valves and cams? .Naturally if anyone has one let me know .thanks
Engine swap-who do I need to inform? husky03 Bikes - Talk & Issues 6 18-08-08 05:06 PM
engine swap this weekend (hopefully all done on sat) fat_brstd Thames Valley 17 23-09-07 09:02 PM
SV650S engine swap LeeSV SV Talk, Tuning & Tweaking 7 26-02-07 08:33 PM
Swap Old Engine into Newer SV? wmrra#30 SV Talk, Tuning & Tweaking 5 21-09-06 11:10 AM
sv650 engine swap toyotafj40s SV Talk, Tuning & Tweaking 5 24-08-06 08:54 PM
