Old 03-06-09, 10:03 PM   #11
irnbrumad
Default Re: Ear Pressure
Originally Posted by ranathari View Post
You sure it's not the helmet? If the foam's worn or its not fitted properly then your ear could be pressing against the shell.
Had my helmet for a good few months but it's not been used enough for the foam to be worn - and previous journeys out on the bike was never an issue with this ear!
I'm stuck for ideas to sort it
Old 03-06-09, 10:22 PM   #12
Kilted Ginger
Could be you are folding your ear when putting on the helmet and not noticing it, sounds strange i know but does happen. Have a feel up inside the helmet when its on to make sure your ear is not folded over, or if you have remveable pads, whip them out and skim a wee bit off the side not in contact with your ear to give you a wee bit more room.
Another thought is the lining could be chaffing the ear, you could wear one of those tube thingys .
hth
Old 03-06-09, 10:23 PM   #13
natcar
I found the autocom headset put a lot of pressure on my ear, and got painful after an hour or two, probably because the helmet was quite a tight fit to start with. You can get different types of headset which dont put pressure on the cartilage of your ear in - moulded in ear type which may be more comfortable though they are not cheap
Old 03-06-09, 10:24 PM   #14
irnbrumad
hth
I've felt it fold over and i do straighten it out
I think i'll have to do some handywork with the pads - they are removable. I'm getting fed up of a roasted and red ear
Old 03-06-09, 10:27 PM   #15
Stu
Trinity
Stu's Avatar
what earplugs do you use?
& the cleaning routine you use?
Old 03-06-09, 10:28 PM   #16
natcar
You could dig out some polystyrene for a cheap fix but wont make your helmet safer. This was what I was thinking of but not tried them http://www.ultimateear.com/
Tyre Pressure evilexel SV Talk, Tuning & Tweaking 5 20-02-09 10:57 PM
Under pressure - again. HELP! krhall Idle Banter 127 03-11-08 09:52 PM
Help! Low oil pressure? gavinsky23 SV Talk, Tuning & Tweaking 7 06-03-08 06:40 PM
Oil pressure light sk5 Apophes SV Talk, Tuning & Tweaking 13 11-01-08 04:32 PM
oil pressure Gauge Apophes Pennine Massive 2 11-01-08 01:11 AM
