#11 | |
#12 |
Mini = falls apart from rust after 3 weeks (4 if you're lucky)
beetle = nuff said, worst car in history and looks like a squashed butternut.. simply terrible datsun 120y = well, the first car to show that cars could be reliable! definatly not a looker nowadays but certainly a car the modern world should be thankful of! |
#13 | |
The Mini has won many awards over the years, perhaps the most notable include: "Car of the Century" (Autocar magazine 1995), "Number One Classic Car of All Time" (Classic & Sports Car magazine 1996) and "European Car of the Century" in a worldwide Internet poll run by the prestigious Global Automotive Elections Foundation in 1999. The Mini managed second place (behind the Model T Ford) for "Global Car of the Century" in that same poll. In the end 5.3 million Minis were sold, making it by far the most popular British car ever made. Thousands of these are still on the road, with the remaining pre-1980s versions being firmly established as collectors' items.
#14 |
I'm not arguing that the Mini isn't simply a brilliant piece of engineering, but cmon admit it..they rust.. xD
I never said it was a bad car. Just that it was a rusty one. ![]() I seem to recall seeing on a documentary filmed by Jeremy Clarkson that each one of the original Minis were sold at a LOSS, also contributing to the whole decline of British Leyland.. among other things.. |
#15 | |
given a production run of 41 years and the last now being 9 years old, of course they'll be a rust problem by now, against the ford Ka, can't see them making that for the same production run
Cheers Mark.
#16 |
Ahh, i seee now
![]() ![]() fiat 500, better than the mini IMO it has more soul... and it's italian you can't go wrong.. apart from electrics. |
#17 |
Far more than one; I assure you, Impact wise the Austin 7 was more a budget car for the masses than the fiat though, built under license in both Germany and America, probably the start of affordable motoring.
#18 | |
Not to mention utterly wrong.
#19 |
#20 |
I always thought lean running did the middle of the piston because it means the charge is burning to quickly and to hot and it's the middle of the piston that gets the least cooling (it also has less mass than the edges where the skirts are). I've got some lovely examples from my two stroke racing days, neat 1cm holes straight through the middle of the piston.... I'm not so sure about pre-ignition though. This happens because the charge ignites before the spark tells it to, just like a diesel engine, and usually happens because it gets to hot during compression, so either wrong fuel or to high a compression ratio....
What are the other pistons like? I can't see pre-ignition affection only one cylinder, but lean running could be down to a dodgy injector on just one cylinder, or I suppose the ECU could be up the duff and telling the injector to deliver the wrong amount of fuel to that cylinder (don't know anything about Ka engines, do they have separate injectors or a common rail?) Either way sounds like an interesting head scratch moment. |
geeks- help me | Quiff Wichard | Idle Banter | 24 | 30-01-09 11:27 AM |
Oi geeks. | yorkie_chris | Idle Banter | 64 | 23-11-08 10:06 PM |
Any IT geeks in here | Cam_73 | SV Ecosse | 18 | 29-02-08 05:15 PM |
So then Geeks | Viney | Idle Banter | 4 | 06-08-07 11:21 AM |
Something for the geeks.... | Baph | Idle Banter | 81 | 16-11-06 04:46 PM |
