Old 17-06-09, 09:22 AM   #11
Sudoxe
Default Re: computer/network knowledgibles
Download NMAP for windows and run a scan on your subnet, i.e
if your network is 192.168.0.0 - 255 with a netmask of 255.255.255.0 scan 192.168.0.0/24
That will tell you everything on the network, and open ports.
Dan
Old 17-06-09, 09:22 AM   #12
Dave20046
Dave20046's Avatar
cool ta, just doing a scan now
hmm results are back - there's a couple of IP's showing as live but the hostname is 'n/a' thinking one of these two might be me switch
Old 17-06-09, 09:23 AM   #13
ophic
ophic's Avatar
only other suggestion is that most switches have a "default" setting - some default to dhcp, others to a particular IP address that you have to look up in the manual.
If you can find this information and a way of resetting the switch to its default presets.... you're in business.
Silver SV650SK3, Fuel exhaust
Old 17-06-09, 09:29 AM   #14
Dave20046
Dave20046's Avatar
Only way to reset to defaults is to run a commandline via a cable that's impossible to source locally. (If I can't get this done today I'll have to order one of the web)
There's a html type admin panel if you type the ip into your borswer (like a domestic router) but for some reason this isn't showing if I type it into my client machine ...hmm...might try that locally. Pretty sure I have the address now.
Old 17-06-09, 09:30 AM   #15
Dave20046
Dave20046's Avatar
Dan
cheers dan, got my answer with angry ip scanner but downloaded that too for future use
Old 17-06-09, 09:31 AM   #16
Dave20046
Dave20046's Avatar
Bingo! Proxy exception added,discovered IP typed and I have a control panel!
Now to guess the password
Anmyway with that knowledge I've added it a reservation now so I'll wait and see if that stops the weird connection drops clients have been getting. Fingers crossed.
Thanks everyone - I'll update as applicable if you're interested.
o2 sim/tesco network irnbrumad Idle Banter 5 13-04-09 10:50 PM
3 network jamesterror Idle Banter 10 09-04-09 12:57 PM
IT network bods plz Wideboy Idle Banter 9 02-05-08 08:04 AM
Mobile network '3' THREE quikstu Idle Banter 6 09-03-07 11:41 AM
Home network help Viney Soho Massive 11 05-01-07 12:08 PM
