#11 |
#12 |
So it's different then aint it :P
#13 |
****, the problem's still not fixed.
The idle speed isn't steady even when the bike's completely warmed up and just bounces up and down over a range of a few hundred revs. All the connectors are in place as best as I can tell so the carbs probably need to be balanced/sync'd, which is beyond me. Booked it into Essential Rubber to get it done because I've heard good things about them. |
#14 |
essential rubber are very good, i feel comfortable taking my bike to them. I can only think its some kind of air-leak, or perhaps the sliders in the carbs are sticking?
I had the good ol' rip-off washers (£240 for parts and labour!!!!) and suffered no problems when they came out.. |
#15 |
The bike's absolutely fine over 80mph so I'm going to time my journey to London today to coincide with the lowest amount of traffic. Finally, a semi-reasonable excuse to speed like a little ****.
#16 |
And now you're off the 33bhp you can get your full quota of points too
![]() What happens when you blip the throttle at standstill? Does the speed stick a little high, then drop down again?
#17 |
Sticky sliders would not cause this problem. Broken diaphragm would not cause this either I don't think.
#18 |
**** me, this thing accelerates like **** off a fan when you roll on the throttle at 90mph.
Blipping the throttle at a standstill causes the revs to increase smoothly and then drop immediately and go back to bouncing around the idle speed. I lifted the tank up and took the airbox out to check connections and they were all fine, so I suspect the carbs aren't balanced, which is the only thing the manual suggests for a jerky idle speed provided there's no air leak. |
#19 |
Bring it to Soho tomorrow night and get the opinon of someone who can actually see/hear the problem?
Thats if Essential havent fixed it by then
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#20 |
All fixed! Essential Rubber balanced the carbs and said the choke hadn't been reconnected properly, which they fixed. It's running perfectly now.
Thanks for all the suggestions and help. I would have done that but the girlfriend's being demanding, pointing out that her exams are about to start while mine have finished and therefore I should be doing her shopping and cooking for her. |
K7 650s fueling. | daveb | SV Talk, Tuning & Tweaking | 7 | 18-07-08 12:12 PM |
Matt's Derestriction Ride!! | Alpinestarhero | Soho Massive | 73 | 18-07-08 08:22 AM |
Fueling upgrade | gazza | SV Talk, Tuning & Tweaking | 2 | 14-06-08 01:59 PM |
Derestriction | Ben Flanagan | SV Talk, Tuning & Tweaking | 11 | 23-04-08 01:01 AM |
K&N Filters & fueling problems?? | robhabens | SV Talk, Tuning & Tweaking | 4 | 29-03-06 11:48 PM |
