#11 | |
![]() Explain yourself in english please is it tar and chippings or tarmac LOL |
#12 |
SMA = stone mastic asphalt - proper tarmac, these days. They're doing a proper resurface, as they'd already planed the old tarmac off when I went down it. No idea how far they've got now though, as I haven't been down since
#13 |
SMA = slippery as a slippy thing when freshly laid as it leaches out the oils and get covered in rain
Not Grumpy, opinionated. |
#14 |
Emily Howard rides an SV
Are they not resurfacing it to put some sort of speed control thing under the tarmac??? Apparently it can gauge the weight of what's traveling on it and judge the speeds while also realising if it's a bike, car, or truck etc.
Or is this utter rubbish??? ![]()
Wowee
#15 | |
![]() sort of, they put sensors under the road to count the axles that use the road, Roads are designed to take Xno MSA which is X no Millions of Standard axles, they use the flow and CV's (commerical vehicle %) to work out the depth of material reqd to give a quantifiable design life to the carriageway, knowing the flow on the route lets them predict future maintenance, they used to use cables accross the road connected to a logger at the side with a cassette in, now its all real time sent using a box with a sim card in, kind of stuff, they can tell vehicle speeds from them but thats not what theyre for, and its difficult cos it counts the axle load and speed as it passes, it would need to know how manay axles each vehicle had to work it out properly, it can be done though, and i dont doubt it will be used for speed detection one day. SMA is stone mastic asphalt , generall y the only surface we can use on trunk roads/motorways in England, Scotland can still use HRA hot rolled asphalt (traditional surface) under certain circumstances, and DBM dense bitumin mamcadam is used more now as well as sma in town as stuff as its easier and cheaper to lay, contrary to popular (daily mail readers) opinion SMA is not slippy or cheaper , its more expensive to buy and its more difficult to lay, but if designed properly and laid properly it has longer life before further intervention is reqd , so whole life cost is lower, there is an issue with early life skid resistance being lower than spec, but not massively so, and it polishs up quite quickly, it just needs to be designed correctly and properly installed. HRA isnt as popular a you need 2 gangs a paver gang and a chipper gang, so you need twice as many men and its a 2 stage process so if one stage isnt right it lets the other down, and you need more traffic management cos the chjippers need as much rom as the millenium falcon. Surface dressing, where they roll a thin layer of tar and roll chippings into it, is a cheap way of sealing a surface to prevent further damage and to lift the skidding resistance and ride quality, its not a crappy way of doing things, its just how HRA roads are kept going, and it done right works really well, you get chips everwhere though. this is what i do, god its dull............................ |
#16 | |
![]() You certainly know a lot.
Wowee
a57 snake pass - is it back open yet? Can't find any info about it anywhere :( | Paul the 6th | Bikes - Talk & Issues | 4 | 07-02-08 12:59 PM |
Snake pass shut due to landslide | Paul the 6th | Bikes - Talk & Issues | 8 | 28-01-08 12:32 AM |
Eyeball: Snake Pass (Sheffield end) Silver Pointy | jamessunhill | Pennine Massive | 0 | 22-06-07 10:01 PM |
eyeball A57 snake pass | fullstop102 | Pennine Massive | 0 | 14-05-07 08:24 PM |
snake pass | bobbydazzler | Bikes - Talk & Issues | 7 | 18-07-06 11:25 AM |
