Old 08-07-09, 05:49 PM   #11
Default Re: 15,000 Miler
there is a hole at the bottom of the engine going right threw if you have a 10mm rod you can put it threw the hole and then use axil stands to keep the front up more secure. you can either use a trolley jack or front paddock stand to lift the front of the bike first then put it on axil stands. if you dont have a 10mm rod then put axil stands under the foot peg u frames. DO NOT WORK ON THE FRONT END USING A TROLLEY JACK.
this is what i use when doing front ends.
Old 08-07-09, 06:11 PM   #12
Kilted Ginger
[QUOTE=Bibio;1966625]. DO NOT WORK ON THE FRONT END USING A TROLLEY JACK.
QUOTE]
pfhhh, hse burocratic nonsense. a jobs mre fun if its a little dangerous, I may try tht axel stand thingy though.
Old 08-07-09, 06:28 PM   #13
Indy definately has a doofer thingmybob for balancing the TBs... It's mine THough you're welcome to borrow it off, er, him. Or me.
Is it valves at 15000? Can't remember. Easy enough if it is though, sounds scary but isn't. Unless you drop a bolt down the cam tunnels into the engine.
Old 08-07-09, 06:49 PM   #14
yup.. valve check at 15000. but to be honest if it has had regular oil changes with good oil then i doubt they they need done.
Old 08-07-09, 06:55 PM   #15
Yup... I mean, mine is on 40-odd thousand now and not a single gap out of spec, which isn't too amazing, but then it's not on the original cams either- the tolerancing's close enough that even putting in a fresh cam and moving one of the old ones everything's still bang on. The paint might be rubbish but the engine's quite well put together
Old 08-07-09, 07:05 PM   #16
Tiger 55
if you have a 10mm rod you can put it through the hole and then use axle stands to keep the front up more secure.
Warning - lots of people have doofer thingmybobs, Husky has one and knows how to use it, but only Bibio has the required 10mm rod. It's his USP.
Old 08-07-09, 07:07 PM   #17
Kilted Ginger
Cm'on now Captain Tiger 55 Sir, you've seen my garage, I've definately got 10mm rod, just not the know how as to where to stick it...
Answers on a postcard
Sorry Cam, I seem to have completely hijacked your thread, I'm sure some nice mod person will delete all the offending posts if you ask him.
Old 08-07-09, 07:23 PM   #18
yes Bibio has a doofer thingimybobs, and knows how to use it.. .
connect hoses to vacuum points. then blank off. warm engine up then stop bike. lift tank, connect gauges, turn screw till volume is same and Bobs your auntie job done. its very very easy on a pointy. curvys are a nightmare to get at the front vacuum point and all that taking bloody air boxes off.
Old 08-07-09, 07:36 PM   #19
Tiger 55
Anyway, I need mine done too, so let me know where and when please.
Old 08-07-09, 09:08 PM   #20
well if someone is willing to donate a garage/lockup for a day, i'm sure i could oblige... must have t and biccies though...
17th/18th May South & West 600 miler Stingo South & West Surfers 1 15-05-06 11:58 AM
