#11 |
Two large washers sat under the throttle bodies, as per a Curvy but with them sat under the Carbs, and there should be a throttle stop fitted too.
#12 | |
Evel Knievel
will look for thrrotle stop also |
#13 |
#14 |
#15 |
Evel Knievel
no look underneath where it clamps onto the carb, there is a screw clamp thing, call you do it loosen the screw off and pull the airboxx off, dont yank it as when it comes off the carbs you will see there is other little pipes that need disconnecting
#16 |
#17 |
Evel Knievel
look under the carbs and you will see and screw clamp holding them onto the intake ducts, you may have to take you fairings off depending on where the screws are situated
#18 |
sorry mate, holding what on??
#19 |
Evel Knievel
the carbs, look underneath the carbs, the intake ducts are what connects the carbs to the cylinders, the washers are inside these sat directly under the carbs
#20 |
Throttle bodies?
Didn't think the pointy had carbs! |
Removing pointy tank? | ibshort | SV Talk, Tuning & Tweaking | 7 | 25-06-09 11:04 PM |
Removing Front Indicators From a Pointy | COLZO | SV Talk, Tuning & Tweaking | 4 | 24-01-09 12:33 AM |
Removing the ecu-restrictor from a pointy | shonadoll | SV Talk, Tuning & Tweaking | 4 | 15-10-08 02:58 PM |
Removing stock exhaust, K3 Pointy | MiniMac | SV Talk, Tuning & Tweaking | 7 | 21-03-08 06:21 PM |
Removing Pointy Lowers | Wadda | SV Talk, Tuning & Tweaking | 0 | 13-03-08 12:35 PM |
