#11 |
Yeah two lines, longest to the caliper left side of bike.
Yep faired bike. It's on the side stand. With regards the rubber pipe to the res, the reservoir on my bike suffered platic fatigue where it mounted to the reservoir mounting bracket, so I got one of ebay. However, it was listed as an 05 sv but is not, so I made up a bracket and mounted it. Thing is the outlet on the res is a bigger diameter than the inlet on top the m/c. Not sure if this would have any effect though.
Silver pointy sk3, tail tidy, single seat cowl, fairing lowers, smoke double bubble screen, carbon hugger and front mudguard, full race M4 system, K&N filter, GSXR1000K2 forks, wheel and discs, GSXR750 calipers, HEL braided lines, TL1000s clip-ons, Gilles rearsets, Chinese cnc levers, led indies. |
#12 | |
#13 | |
Silver SV650SK3, Fuel exhaust |
#14 |
#15 |
I too recently had a brake bleeding issue, never had one before. The pads were pushed out against the disc but could get no resistance at the lever.
![]() In the end I pushed the pistons back into the callipers, which forced brake fluid back up the hoses. That brought out what I can only describe as pepsi brake fluid, it was so aerated! You might try that or using a syringe to force brake fluid up from the bleed nipple. It worked for me. ![]() |
#16 |
Ta very much, all done and dusted now.
Tried your method flymo but after 10 mins no sign of fluid drop in the res or any coming through the bleed nipple so thought I'd crack on with the usual method. Got some good feel through the lever very soon after, don't know if this was down to your tip or whether it was coincidence and it was nearly there already or not, but cheers for your input folks.
Brake bleeding help | Neeja | SV Talk, Tuning & Tweaking | 27 | 15-07-09 07:15 PM |
Brake bleeding-where am I going wrong? | rowdy | SV Talk, Tuning & Tweaking | 20 | 02-02-09 10:36 PM |
Brake bleeding kit? | gstrong82183 | SV Talk, Tuning & Tweaking | 38 | 28-03-08 10:07 PM |
Bleeding new brake lines | andyb | SV Talk, Tuning & Tweaking | 1 | 25-01-07 06:10 PM |
Brake Bleeding - Two Questions | Colboy | SV Talk, Tuning & Tweaking | 16 | 24-01-07 10:04 PM |
