Old 03-09-09, 07:15 PM   #11
Beut834
Default Re: Help - New biker naive and confused!
So is the spring the answer?
Old 03-09-09, 07:21 PM   #12
No, the height is controlled by the shocks extended length. spring will not change anything.
Also you could change spring, but it would handle really badly since the standard shock has no damping in it anyway.
Old 03-09-09, 07:25 PM   #13
Old Git
Old Git's Avatar
Chap, there are much more technical guys on here than me, but I only passed my test in Feb, have eaten way more pies than you & can stand over the bike as well.
You know best for yourself, but why not give it a little while.
I found I started sitting upright & looked a bit of a , seen self in shop window, but as I've got more used to riding, find i have changed seating / body position & all is well.
Still never going to look or ride like Rossi, but how often are you sitting bolt upright on the bike on any ride? very seldom i guess.
Hope you enjoy your new toy - OG
Old Git is offline   Reply With Quote
Old 03-09-09, 07:26 PM   #14
Spiderman
Where the hell am I?
Spiderman's Avatar
how tall are you?
And where in the country are you? Seeing and talking to others of a similar size to you on their SV may help you feel a bit better or make a considered decision.
Old 03-09-09, 07:29 PM   #15
Biker Biggles
Biker Biggles's Avatar
Shorter dogbones will raise the rear.You can also raise the yokes so that they are flush with the fork tops to even out the steeper steering and raise the front a tad.
Id say you would also benefit from stiffer fork springs and a rear shock upgrade both of which would reduce sag and hence raise the bike a bit.Is the bike fitted with a sculpted out rider seat?Many svs are,as they have been used by the vertically challenged in earlier lives.
Old 03-09-09, 07:39 PM   #16
TazDaz
How massive are you? Has the bike been lowered for a previously shorter rider?
Old 03-09-09, 07:42 PM   #17
Beut834
6 ft and I am living in Germany presently! - so Spiderman's suggestion is no good! Thanks anyway!
Old Git - sounds like sensible advice!
Biker Biggles - Sounds expensive?! I am fairly sure the seat is standard! how much would the work you suggest cost? (ballpark figure!)
Old 03-09-09, 07:45 PM   #18
Beut834
Yorkie Chris - would a combination of shorter dog bones and bigger springs do the trick?
Old 03-09-09, 07:47 PM   #19
How much do you weigh?
Old 03-09-09, 07:49 PM   #20
Sally
6ft, and 15 stone plus/minus a few pounds.
Keep up
new fresh and naive SV owner saying hi duibhceK Idle Banter 23 06-09-09 01:41 PM
I think I may have been naive with sparkplugs. poisonidea Bikes - Talk & Issues 10 16-05-08 07:35 AM
Confused..?? SVNez SV Talk, Tuning & Tweaking 3 10-08-07 05:31 PM
I'm Confused Lissa SV Talk, Tuning & Tweaking 3 29-07-06 08:42 AM
Confused!Where do I go? Whitty Pennine Massive 5 14-06-06 09:14 AM
