Old 13-09-09, 09:04 PM   #11
thefallenangel
Default Re: Valve clearance, should I take it?
if you don't want to get it done recheck it in say 6k so you won't be too far off, if it gets any worse then change it. As has been said you are talking tiny sizes which aren't vital but need to be inspected more often if you aren't prepared to pay for a replacement yet.
Old 13-09-09, 10:18 PM   #12
Binky
Emily Howard rides an SV
Binky's Avatar
Sorry to hijack this thread.
But what are the symptoms of poor valve clearances???
Wowee Zowee
Old 14-09-09, 12:17 AM   #13
jambo
jambo's Avatar
The short answer is there aren't any. They are the DIY maintenance opposite of lubing your clutch cable: lots of effort and you can't really tell a difference. Frankly my engine sounds might much nicer BEFORE I adjust the clearances, at which point is starts sounding rattly,
To the O.P.
At 0.09mm I would personally change it but that's because I can do it myself and I schedule the time in for sorting these things. I wouldn't fuss that I'd have an issue for the next few thousand miles if I ignored it though.
Jambo
Old 14-09-09, 06:16 AM   #14
Old Git
Old Git's Avatar
Thanks peeps for the replies.
Old Git is offline   Reply With Quote
Old 14-09-09, 10:01 AM   #15
lee67
ran plenty of bikes up to 50,000 miles with no valve checks/adjustments.....if u let ur bikes warm up good and dont rag em all day then most will find they dont need doing, also change the oil/filter is the main thing here
Old 14-09-09, 10:27 AM   #16
timwilky
timwilky's Avatar
Default Re: Valve clearance, should I take it???
I would leave it... thats only 0.005 thou of a gnats willy away.
not worth bothering about to be honest.
Back to school mate
.01mm out is less than 1/2 a thou. Actually it is 0.000393" so in in proper money .4 of a thou.
Not worth faffing about with. As others have said, leave it to the next scheduled check.
Not Grumpy, opinionated.
Old 14-09-09, 10:30 AM   #17
ophic
ophic's Avatar
Back to school mate
so they taught you the size of a gnat's willy at school? I must've been absent that day!
Silver SV650SK3, Fuel exhaust
Old 14-09-09, 10:41 AM   #18
SoulKiss
SoulKiss's Avatar
It was pointed out to him in the School Nurses office, just after they told him to turn his head and cough
Old 14-09-09, 10:54 AM   #19
timwilky
timwilky's Avatar
Actually guys. When I first started my apprenticeship we worked on some tooling to 1/10 of a thou. More like gnats foreskin than willys.
One medical I had was a bit more than drop and cough. The works doctor supported them on a large catering spoon for the cough bit. comforting that the spoon was cold. it must have be cringingly warm at the end of the line
Old 14-09-09, 11:16 AM   #20
ophic
ophic's Avatar
you do seem to know an awful lot about the anatomy of a male gnat's reproductive system
Valve Clearance Readings Mr_Chin SV Talk, Tuning & Tweaking 2 22-12-08 08:54 AM
Valve clearance checking. Mark_h SV Talk, Tuning & Tweaking 6 22-12-08 08:31 AM
A question of valve clearance... BillyC SV Talk, Tuning & Tweaking 11 23-11-05 12:36 AM
15k service - valve clearance The Mass SV Talk, Tuning & Tweaking 21 18-08-05 09:41 AM
Valve Clearance Craig SV Talk, Tuning & Tweaking 3 14-02-05 07:34 PM
