#11 |
Pin overide will only disarm the system, it wont turn the alarm off full stop, once you turn the ignition off, the alarm will set 30 secs later................
You can by pass the system by removing the pcb and fitting jumpers accross 4 specific wires, to re-connect the immobiliser circuits, best way is to remove it out of the wiring system entirley. |
#12 |
i just removed one completely pain in the bum but worth it.Dont think much to datatool that was on my wifes bike , much prefere my meta on me thou.
#13 |
If you spend time now trying to fix it, you will only hate yourself more when it leaves you stranded AGAIN!
'Datatool' and 'transport' should never be used in the same sentence, and certainly not on a bike. Get rid! |
#14 |
I ripped mine out too.
Best move ever. |
#15 |
Thanks for the help so far guys.
Right then. I've ripped the sod out.... BIKE PICTURES 001 (Small).jpg I've sorted everything except these four black wires, but i can't see anything to connect them to. Where do they go?! BIKE PICTURES 002 (Small).jpg BIKE PICTURES 003 (Small).jpg Told you i wasn't very good at electrics..... ![]() |
#16 |
if you go to the datatool website theres a section on there that if you put the make and model bike you have, they will tell you what is wired to what.
#17 |
Did you check the alarm fuse? its out now but just wondering
#18 | |
right old chum bet you've lost your fuel pump ? here's your lesson , strip loom back a little bit more and you will find where they have tagged them 4 wires in probably on something like red/white, brown black, orange green and can't remember other colour. I'll attach a wiring diagram to help you but if you search my posts you will find my thread about it- lesson continues before your alarm was installed there was a alarm plug on the end of them wire's one plug had 4 wires in with 2 bridged and the out he plug just one black wire , which goes back to a small white block with 5 white/black wires and your one black wire just tape this one off its not needed till you have a alarm fitted!!!! as for the alarm plug don't worry that its not there once you have peeled back loom abit you will see where they have tagged on to your wiring you need orange with white tracer take White from here then get you mode select switch socket white with a black rubber cap ! attach wire from orange /white to orange green and she will be alive again you can just tape up other tagged on wires or remove the it's up to you! i also had a extra live coming out me fuse box just tape it up if you have one hope this helps look at my other thread ill attach wiring diagram that helped me , where abouts are you? |
#19 |
SHE'S ALIVE!!
Thanks so much for all your help guys. Sz1, it was exactly what you said. I'm off to get my soldering iron and leccy tape, and then i'm off for a ride! ![]() Thanks again everyone, i love this forum. Matt. ![]() |
#20 |
glad she's alive and kicking , only reason i could help was because some one of here gave me the diagram , so yes this forum is cool.
Grrr! Flipping Cage drivers! | Lissa | Idle Banter | 22 | 05-03-09 08:34 PM |
Battery...HOW FLIPPING MUCH!!! | BigBaddad | SV Talk, Tuning & Tweaking | 40 | 20-05-08 10:47 PM |
Flipping Kids! | Lissa | Idle Banter | 23 | 19-05-08 09:44 PM |
Flipping kitten! | Paws | Idle Banter | 14 | 21-06-07 09:43 PM |
Flipping Pirelli Dragon Supercorsa | joeappel | Tyres | 2 | 01-09-04 05:18 PM |
