Old 21-10-09, 03:54 PM   #11
Daimo
Default Re: New paddock stand loose. This normal???
I've got a cheapy paddock stand and it has the same issues as yours.
However, after doing some servicing on the Bandit this weekend (1 of my damn center stand bolts has gone walkies???), and replacing an entire engine on my SV, it won't go anywhere
If your unsure, just bang a new bolt through it and put a nut on the other side to stop it sliding left/right.
I removed the silly springs from the swinging arm support, so just manually allign them to the swinging arm when putting the stand underneath.
Old 21-10-09, 03:57 PM   #12
Originally Posted by N8te rider View Post
If I slowly twisted it back into alignment, would that weaken the metal?
Should be ok, so long as you don't put a kink in the tube. Steel has some inhierant flexibility
Old 21-10-09, 08:26 PM   #13
madnlooney
these are the stands i was gonna get. apart from the alignment are they good value?
Old 21-10-09, 08:36 PM   #14
monkey
... I wouldn't recommend leaving it unattended for too long, just in case it slipped off...
He he he.
Old 24-10-09, 02:36 PM   #15
madnlooney
well i did order these and put together last night. the rear is ok, i rockd bike abit and its stable enough that id work with. im being thick and dont know how to use the front one. anyone have any pointers? so cant say how that one is. but over all for £45 i cant grumble.
Old 24-10-09, 06:02 PM   #16
N8te rider
Hi. just used mine today. Was stable enough but not great quality. After using them one of the wheels fell off (well, the e clip did. luckily they come with spare ones). But overall good enough to work with.
About the front Stand: its kind of upside down with the forks sliding in between the two rubber bits. You'll notice the back of the SV's front fork has a lip about an inch up from the centre bolt (which holds the wheel on). This is what stops the stand sliding all the way up the forks. Ive attached a drawing (hopefully) to help explain.
Old 24-10-09, 07:27 PM   #17
madnlooney
thanks for drawing. managed to do it different, the lower rubber bit under the fork and the other on back of the fork in the lip. will try as draw shows see if its any different. broke one of the rubber bits off already haha
Old 25-10-09, 11:05 AM   #18
N8te rider
Yep, Shoddy quality. I've cut some hose pipe and slid it over them. think it will make it last longer. Oh, what fun.
Old 25-10-09, 11:22 AM   #19
ive got "champion stands" but i sold the front as i just couldnt trust it, i only use the rear.
Micron Front Paddock stand, Arrow-style LED indicators, Chrome Eagle-Eye indicators, Rear paddock stand Aluminium bobbins for swingarm.... lucky strike For Sale - Other Bikes and General biking items 12 27-08-09 12:00 PM
Paddock stand/abba stand or? Ruthja2801 Bikes - Talk & Issues 18 26-02-09 12:20 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
Paddock Stand Dee4Life Bikes - Talk & Issues 11 24-12-06 05:51 PM
Paddock stand The Basket Stuff Wanted 0 03-12-05 10:49 AM
