Old 22-10-09, 12:10 PM   #11
walkaboutandy
Default Re: Import bike with no carb heaters. Will the loom be wired for them?
Originally Posted by Taipan View Post
Top man. Thanks for that info. I left my manual at my In-laws and thats saved me a journey to collect it. Did you get a whole wiring loom or just the carb bit?
No, I just got the carb bit of the loom with the thermoswitch included (soild black thing on the end of 2 wires). The small loom (just goes round the carbs) basically has 4 connectors for the 2 heaters (2 connectors each, one for + and one for -), one connector for the thermoswitch and one for the main wiring loom.
Old 22-10-09, 12:11 PM   #12
walkaboutandy
Some folk see the heater loom as part of the loom, others sell that with the carbs.
Out of curiosity, are the imports carb bowls drilled and tapped for heating elements?
Good point, I'll let you know when I have a look later.
Old 22-10-09, 12:26 PM   #13
Taipan
Taipan's Avatar
Just sourced one from ebay too. Just hope the Italian SV loom has that plug, although getting a igntion 12v live shouldn't be too much of a problem.
Old 22-10-09, 07:13 PM   #14
walkaboutandy
Well mines French and that has the plug so you should be OK.
Old 22-10-09, 07:29 PM   #15
Alpinestarhero
Is it really so much warmer over the channel that they dont need carb heaters?
Old 22-10-09, 07:31 PM   #16
walkaboutandy
Yes they are, so if you want to UK spec your bike then you just need the heaters, the loom and the thermoswitch. Its a bit pikey of Suzuki to not fit them on every bike. I would have thought that some of our European cousins would need carb heaters much more then us Brits!?
Old 22-10-09, 11:09 PM   #17
We've been here before, and I wouldn't bother fitting them, they don't have anywhere near enough effect to be worth it.
Old 23-10-09, 07:55 AM   #18
Taipan
Taipan's Avatar
I must admit my old ZX9 would have been badly suffering from carb icing by now! Oh well the parts only came to £12 and it does complete its transformation into a UK spec bike. So I guess it doesn't matter. Apprciate the comments though, its always good to learn more about these bikes.
Old 23-10-09, 08:16 AM   #19
sz1
i got aloom of these guy's cheap as well , i got a loom for a different reason butmy point is if you find out which loom your's should have as uk spec there are differnt ones for some years just order a loom if yours doesent have plufg for heaters and bob's ur uncle.
http://www.svspares.com/
Old 23-10-09, 09:35 AM   #20
Taipan
Taipan's Avatar
Thats a handy link! Thanks very much.
Carb Heaters thedonal SV Talk, Tuning & Tweaking 17 08-01-09 03:29 PM
Carb heaters drag Stuff Wanted 5 29-09-08 01:28 PM
Are my carb heaters draining my battery? svrash SV Talk, Tuning & Tweaking 12 27-12-06 11:13 PM
Carb Heaters (again) anyone got the part #? echomadman SV Talk, Tuning & Tweaking 8 12-01-06 06:36 PM
carb heaters rastas SV Talk, Tuning & Tweaking 8 12-03-05 05:19 PM
