Old 20-11-09, 03:42 PM   #11
RichT
Default Re: SV650 or Bandit 600S?
I owned a blandit 6 as a first bike and it does exactly what it says on the tin in a very reliable fashion. Good first bike, good commuter (arguably better than the SV), but it doesn't excite you the way the SV does. Either would be ideal as a first bike, I'd say the difference is that you'd get away with being a little more ham fisted on the bandit.
Can't comment on the Yam, but your instructor is talking b_llocks. Do that too energetically on any bike mid corner and you're likely to step the back end out and find yourself on your backside.
Test ride, test ride, test ride.
Old 20-11-09, 03:45 PM   #12
beabert
V is my first proper bike. Sure, I didnt expect it to be quite so fierce on the downshift
Shocked me too lol
Old 20-11-09, 05:29 PM   #13
liamsimpson
Hi, I have ridden many things in the past for 50cc scooter (still do) to a turbo charged hayabusa. The sv is a good bike to start with and excellent if you are experienced enough to push it, the down shift is interesting if your not used to it but after riding it for a short while you will get used to there habits. I have to say riding a bandit for 6 months as a carrier it was good for the commute but doesn't quite have the umph of the SV also like you say the Bandit gets boring after a while. Out of all the bikes i have owned and ridden the sv is the most fun, easy to ride and reliable. Build quality on all Suzuki's is not great but look after them and they are spot on.
The turbo hayabusa by the way was stupidly, ridiculously fast!!!!!
p.s welcome to the forum.
Also test ride both because only you can make the decision of what's right for you.
Liam
Old 20-11-09, 06:01 PM   #14
Rob969
As someone who went out and bought a curvy as a first bike (never riden anything until doing my DAS) i can definatley recomend it as a first bike. It can cope well with mile munching, i did 400 miles in a day on mine with no problems. plus its got enough character for when you want to go for a blast and I was suprised just how well it went when put against sports 600's on a track day. don't let the fact that its a v twin put you off you get used to it in no time.
ps
Old 20-11-09, 06:12 PM   #15
L3nny
L3nny's Avatar
I bought an SV as my first bike, only negative is that at low speeds the throttle is a bit snatchy which when I first started took some getting used to.
On the plus side the power comes in at an even rate throughout the rev range so it's much easier to predict, unlike an IL4 which has a power band at the top.
I have ridden a Bandit and a Fazer 600 and they seem boring compared to the SV
2015 GS 1200 Adventure
Old 20-11-09, 06:19 PM   #16
Rob969
i'd agree with that,
Old 20-11-09, 06:30 PM   #17
TazDaz
Originally Posted by mikky View Post
My instructor has totally put me off the bike.
he can’t recommend it to a new rider because of the torque of the V-twin, and I can see his point. He reckons in the wet, through a corner, if you shift down one too many gears, you could be in trouble when let the clutch out and pull the throttle.
So come on… should I leave the SV till I get some more experience, or go for one straight away?
Surely this could happen with any bike?!?! You'd have to be pressing pretty hard I reckon to have that happen on an SV...and besides you should have the gears sorted before you are in the corner so you'd only get into to trouble if you were being a bit silly in the wet.
Just get what you want. My SV is the first bike I've ever had and I think it's a brilliant first bike to have. No complaints at all. It's light, quick enough and easy to ride.
Old 20-11-09, 06:32 PM   #18
Holdup
I passed my test and got straight onto my sv (ok its restricted but it still has the torque) and im yet to do any thing like that you shouldnt experience any problems i wouldnt of thought unless you did bang right down the gears
Old 20-11-09, 06:52 PM   #19
sv-robo
Originally Posted by ophic View Post
The SV is fine. Like changing any bike, get used to it before you nail it. The Bandit is fine too but somewhat bigger and heavier. And uglier. Mind you you've said you like curvies so taste could be a problem here
Bandit might have slightly more power(but hardly noticable)the sv makes up for it with the torque & fun factor....sv all the way imo(in the shape of a pointy)
Old 20-11-09, 07:22 PM   #20
Bedhead
Bit of a pointless excercise but:
Bandit 600S 78bhp, 208kg, 375BHP/Ton
SV650S 70bhp, 165kg, 424BHP/Ton
Fazer 600 95bhp, 189kg, 502BHP/Ton
All these are for the manufacturers specs, so obviously they ain't accurate, but it shows that the Bandit is a slug compared to the SV and a hell of a lot slower than the Fazer.
Last track day I did, my mate brought his old Fazer along and everyone was shocked at just how bloody quick it was, it's not really a valid comparison to the bandit, which in effect is a parts bin special which just happened to take off in sales.
As said before, if I had to ride 400 miles, I'd take my Bandit, if I was out for an afternoons fun, I'd take the SV.
SV650 Vs Bandit 600. andrew311 SV Talk, Tuning & Tweaking 42 09-09-09 12:40 PM
12 Bandit tae sv650 curvy mabozzar SV Talk, Tuning & Tweaking 24 26-08-08 03:21 PM
sv650 bandit seat rallyjon SV Talk, Tuning & Tweaking 8 29-04-08 07:17 AM
SV650 after a Bandit 650 ccurts SV Talk, Tuning & Tweaking 13 16-04-07 08:56 PM
SV650 or Hornet 600s Spewy Bikes - Talk & Issues 16 12-06-05 06:35 PM
