#11 |
Where the hell am I?
Regarding the damp and rot bit.....Wow, i'm surprised the mortgage company lent on this without first insisting that you get the damp survey and estimate. In all my years in property sales in london they insisted on this and would sometimes even retain some of the money till the work was done.
Its also a good negotiating tool for you as a buyer, if its gonna cost £3k for example, to get the work on then you could justifiably ask for £4-5k off the agreed price for the inconvenience etc you face whilst getting it done.
. "Computers are great! Not for communicating tho. They have one fundamental flaw ... they don't have eyebrows." AlpineCarStereo: you win ....... eeerrr ..... ummm ..... my undying support of you, the greatest Mod this forum has ever known. My Leige. davepreston: ![]() |
#12 |
It's nowhere near as bad as it seems, the surveyor is just covering his ass. The walls are not even showing up damp, it is only readable with a meter. The rot is standard for a house of this age (1895) and the woodworm is easily treatable.
I couldn't be arsed to f about for a couple grand, as the chain was very close to falling apart. I would add that this is MY homebuyers report, not the banks valuation report. Regards Phil |
#13 | |
Kenwood http://www.kenwoodplc.co.uk/ were the first port of call for most agents to get a free report and quote from for damp and rot but were never the cheapest. A good start point tho.
#14 |
Did you get any form of guarantee paper work relating to the chemical DPC your survey mentions? These things normally have an insurance backed warranty which is quite long, so maybe that work is covered? Check for that and if the DPC is breaking down then you should be covered.
Damp at the first floor level is unlikely to be rising damp though, because the downstairs walls would be soaked! Sounds like damp is either running down the walls from the roof or is penetrating the render. The roof is the easiest to check first. Make sure the gutters are sound and clear of obstructions, ensure all water that enters the gutters stays in then and does not leak down the wall. Then check that all water that drips off the roof ends up in the gutter and not dripping back onto the wall. Finally double check that the roof at the edges does not leak onto the top of the wall. If all that is good, then it is likely that the water is getting through the render. I have no knowledge of how to investigate / fix that though. |
#15 |
You bought your house like that?
I'd have run away! Best of luck fixing her up. I'd be pessimistic rather than optimistic with damp. My gran had a little damp in the kitchen, and when they investigated they found a drippy pipe under the sink, that had gone un noticed for a while had sent things into rot orbit, she had the entire ground floor ripped up, and all the walls pulled down to bare brick as dry rot had gotten in, there were some real wacky shrooms growing under them floor boards! I know my own house is a bit damp in the loft, but I know for certain the ridge tiles on the roof need fixing, and the house needs re-pointing. My house is as dry as a bone with no damp. Has all the cavity wall insulation etc but if the outside is left any longer it could cause a multitude of problems. So in Spring I'll be getting it fixed before it costs more money.
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 Last edited by dizzyblonde; 16-12-09 at 12:22 PM. |
#16 | |||
I know the render is poor in a few places (good in the rest though), and theres a few cracks around windows/facias etc. There is also a leaky bit of guttering (all mentioned in the survey). There may be a possibility that some is coming in where the roof meets the wall, by the old chimney (this has been removed but is visable from the loft) and I will investigate when I get time. Quote:
#17 |
You could always do what my student slumlord did, which was to paint over the mold every year. I was in the downstairs front room for my first year in the house and the walls gradually turned greeny-black, everything felt just a bit moist. Moved upstairs for the second year and he had his dodgy belching builders in to paint over it all. Hot half-Polish girl with exposed midriff (*drools*) moved in there, and the walls began slowly changing colour, all her clothes and stuff were all ever so slightly damp (yes yes, gusset included) but slumlord didn't care.
#18 |
I think I'll sort it if it's all the same to you!
#19 | |||||||||
1895 you say? The walls will either be solid stone or brick or have a pretty rudimentary cavity. Quote:
Modern chimneys we build with llead sheets in them so that the damp only gets so far down. Big problem can be the capping on the top. Quote:
But obviously *some* gets in and you cant leave them. Check the corner fittings on the gutters and make sure they aren't blocked. Quote:
It also has the effect of ensuring that the cellar walls get saturated behind the tanking. Previously they did dry out a little bit by leaking into your cellar space ![]() This sometimes cause problems higher up the walls than previously. 1895 you say? It's an old house; it will have damp bits ![]() BTW. Dont take any of the above as any kind of substitute for talking to a 'local' builder. Older houses in any given area tend to have peculiarites of construction and materials. If your house falls down, blows away etc its not my fault. Ask around lots to find a builder who comes reccomended. Even if you have to wait. 12 month long diaries are still very common believe it or not. Last edited by skeetly; 17-12-09 at 10:36 AM. |
#20 | ||
PVC tube for sorting front preload | stuballs | SV Talk, Tuning & Tweaking | 5 | 12-11-09 12:34 PM |
Sorting suspension on a ZX6R | andyb | Bikes - Talk & Issues | 11 | 06-11-07 07:49 PM |
Help sorting GSXR front end search | JuicyGuzzi | SV Talk, Tuning & Tweaking | 15 | 23-08-07 01:11 AM |
Sorting out the fuelling. | the_lone_wolf | SV Talk, Tuning & Tweaking | 9 | 13-08-07 11:18 AM |
Sorting the handling | andyaikido | SV Talk, Tuning & Tweaking | 3 | 28-05-06 08:24 PM |
