Old 01-01-10, 03:56 PM   #11
rictus01
rictus01's Avatar
Default Re: Optimate 3 question, yes I am a stupid numpty
......all very sensible stuff.......:
But, but I like fireworks.........
Old 03-01-10, 09:02 PM   #12
ThEGr33k
From my experience generally speaking if the charger says its charged then it should be. If you take it off of charge without turning mains off first it shouldnt matter...
The fact that when you reconnected the charger it took a little while to go green again could point at ell knCkered battery... What the charger does is charges till the voltage reaches 14.3V then goes to 13.2V and keeps it at that.
With a good battery that is showing charged you should be able to disconnect it and then reconnect it and see the charger go to fully charged pretty much straight away.
Sooooo. New battery I think.
Old 03-01-10, 09:32 PM   #13
It might be new battery time but the above doesn't say so.
The charger will reset its progamme when the connections are removed, an Optimate almost certainly won't go back to reading fully charged straight away.
Old 04-01-10, 10:55 AM   #14
ThEGr33k
Mine does... As soon as the voltage goes so high (asin the voltage of a full battery) it goes to maintain.
Old 11-01-10, 01:28 AM   #15
skyline
Right, I've bought the TM71 lead and been spending this evening trying to hook it up to the battery terminals.
The big problem I have is that the red insulating cover which goes over the positive battery terminal is now unable to go into place because the eyelet lead is in the way.
With it being an insulating cover, would it be dangerous not to have it in place? Would cutting a slot into the side of the cover (so the cover would split either side of the lead) be a way round it?
Also I'm placing the eyelets between the loom connectors and the battery terminals, this is ok isn't it? A dumb question but I'm fearing if they're in the wrong place something bad may happen when I next start the bike...
Cheers loads again everyone
Old 11-01-10, 11:47 PM   #16
Put the charger terminals above the existing originals, ie between the screw and the bike's battery connections, to avoid a reduction in contact area between the battery terminals and the starter cabling.
it's sometimes possible to thread the new connector through the red cover, ie the way the original cable does. The new ring terminal will have to be bent through 90 degrees to follow the original wire.
Old 12-01-10, 06:12 AM   #17
skyline
Awesome, cheers loads Sid Squid! I'll have a crack at it when I next see the bike
Old 12-01-10, 09:53 AM   #18
ophic
ophic's Avatar
Connect the negative jump lead to a clean unpainted metal part of the frame or engine...
on a Suzuki?? Houston, we have a problem
Silver SV650SK3, Fuel exhaust
Stupid Van Question Sosha Thames Valley 24 30-11-09 08:42 AM
Optimate question Lozzo Bikes - Talk & Issues 4 15-12-08 05:47 PM
Numpty question again....brakes cuffy SV Talk, Tuning & Tweaking 7 27-02-06 04:58 PM
Stupid question??? Ash999 SV Talk, Tuning & Tweaking 1 22-02-05 07:21 PM
Stupid question..... Jabba 2005 Annual Rideout 7 21-02-05 02:24 PM
