#11 |
So run a chunky Flylead off the Positive and Negative to a roomier area then , and then run some sort of connection system off that for anything I want to add to it then and junk them ring connectors ?
And Bibio , it was only the one dodgy wire which was the result of a bit of stress on the loom from fitting an ABM comfort kit , the rest of the bike is sound electrically ....................................... so far ............ Gulp . |
#12 |
Yeah, and remember when fusing stuff, fuse should be on live as close to supply (battery) as possible.
#13 | |
I will probably fit some sort of "Potted" system around it all with Silicone once done , you can buy small "Snappy" boxes from Maplins , I could drill holes for wires in that and thread them through and make the connections good , snap the box shut around the relay and then Pot the holes with Silicone and around the edge of the box as well where it seals . Or , sling a thick bag over it , cable tie the end of that around the wiring and pot that . |
#14 |
Doesn't need that much, just don't have it outboard of frame, pointing forwards on a naked. Or it will die, no matter how much grease you slather it in!
#15 |
It is going to hide behind the Rad on my Pointy where the OEM horn is , so will not be directly in the elements but will still need some sort of protection . I am going to undo the horn , plug the relay in place of that and then secure it afterwards once the rest of the wiring is done .
Some good advice there guys , just need things to be a bit less than Zero outside so I can get out there and do it . I`ll take a trip to Maplins tomorrow for bits and bobs ............ I`ll need some fairly hefty Gauge wire then for this ...... 14 16 ? |
#16 |
Move it behind headstock?
#17 |
I wrapped my relay in cloth then put it in a bag and tie wrapped it shut. My nautilus is beside my radiator and has been fine in all weathers
#18 | |
![]() I have read a post on Sv.rider.com about splitiing a Nautilus down into 2 parts. One half is the compressor, which can be split from the noise maker. Saves a lot of space. I'll try and find it
#19 |
Here you are. He hasn't done a particularly neat job, but it does show that the horn can be split into 2, which makes siting it easier.
http://forum.svrider.com/showthread....ghlight=stebel
#20 |
Well if the wiring for the OEM horn is moveable then I can sling the relay anywhere , I`m expecting it to have little movement though in true fashion . If you can split the Horn that would be ideal Maviczap , I can hide the compressor in the rear and run some airline to the horn .
STEBEL Nautilus compact air horns (new) | markmoto | For Sale - SV's and SV related items | 12 | 14-12-11 09:03 PM |
Stebel Nautilus Horn | appollo1 | For Sale - Other Bikes and General biking items | 2 | 20-10-09 07:52 PM |
Stebel Compact Nautilus | ibshort | Stuff Wanted | 1 | 21-05-09 01:10 PM |
Stebel Nautilus air horn SOLD | Nobbylad | For Sale - SV's and SV related items | 4 | 19-02-09 11:44 PM |
Stebel Nautilus Horn | philthunder | Ancillaries | 2 | 06-03-05 09:57 AM |
