Old 23-01-10, 01:54 PM   #11
MGI
Default Re: Which socket set?
Thank you very much for help - I will go for Halfords Pro set.
Will have to only decide for which one
Michal
Old 23-01-10, 02:02 PM   #12
Taipan
Taipan's Avatar
6 point sockets pull on the flat of the nut and not the "points". So you get more contact on the nuts surface area.
Old 23-01-10, 03:42 PM   #13
timwilky
timwilky's Avatar
Not necessarily so. The issue is that you need your tool design to be such that the turning forces are delivered through the flat of the fastener and not across the corners of the hex.
As stated above 6 point delivers more surface contact. But it still needs the contact to transmit the forces in the right place. A poorly designed 6 point is just as bad as a poorly designed 12 point.
12 point is better where access to rotate is restricted, but generally 6 point with the greater surface contact area permits higher torques without damaging the fastener
Not Grumpy, opinionated.
12V Cig Socket Socket Etc. Sally SV Talk, Tuning & Tweaking 48 05-11-09 01:36 PM
what size socket? kwak zzr SV Talk, Tuning & Tweaking 13 10-05-09 07:16 PM
what size socket? larigos SV Talk, Tuning & Tweaking 6 30-03-09 12:17 PM
Socket sets dmracing SV Talk, Tuning & Tweaking 35 26-08-07 11:08 PM
Socket AM2 Motherboards M65 Idle Banter 8 28-11-06 11:31 PM
