#11 |
There is another one on the piece of casting which connects reservoir to shock, that is compression adjuster. It is a flat head screwdriver type adjuster.
#12 |
Added another pic so you can see where the damping adjusters are. Its 335mm eye to eye. Spring is 81.6mm across.
#13 |
Im interested to see how this pans out, please keep us updated
#14 | |
I asked on SV rider and there is a guy on there with longer dog bones and a zx10 shock and he has no clearance problems. ![]() http://forum.svrider.com/showthread.php?t=118690 Last edited by Taipan; 10-02-10 at 01:53 PM. |
#15 |
That's a weird one. Can't see why there would be any clearance issue. Mine was very close but definately not touching. The bottom fork isn't the wrong way round is it? I don't even know if that it possible.
Raising the rear up would surely give you more clearance?
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. |
#16 |
That looks like the same shock as I've got fitted on my curvy.
As Mr Speirs said should fit, close but no touching The only Issue I had was the well documented issue on the bottom of the shock. The sv sock is threaded whereas the ZX isn't. You need to use the bottom bolt from the ZX shock. Also IIRC the mounting is not dead central so the bolt will foul the swingarm if fitted on way but not the other way ![]() HTH |
#17 |
Hoping to fit mine this weekend along with an undertray. So if anyone has any fitting tips or hit any snags when fitting theirs I'd be glad to hear of them. I'll trawl the archives anyway, but if anyone thinks of anything they wished they'd known first please let me know. Ta.
#18 | |
#19 | |
To accomodate the res I cut a playing card sized hole out of the battery tray right along the 90degree seam on the left (is you are sitting on the bike) hand side of the tray. I then built up the remaining tray til it was about 2mm above the res with stiff foam andrested the battery onto its side (it fits very tightly and doesn't move an inch) to do this though you will need to remove the tank bracket and hacksaw the old battery holding bit off and bend the remaining metal flat against the bracket, also you will need to free up the negative connection lead to reach the new location of the terminal remembering to keep the lead running inside the subframe. That way you don't need to cut into the seat. Ive done 2 now this way. Oh and remove the rear plastics. and remember to order the kwak bolt for the bottom shock and fit it the opposite way to which the original shock was bolted.
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. Last edited by Mr Speirs; 10-02-10 at 03:43 PM. |
#20 | |
Whoops. I fogot less is more!
Much appreciated. ![]() |
ZX10 Shock on a Curvy | TheShadow | SV Talk, Tuning & Tweaking | 27 | 15-06-09 10:33 PM |
ZX10 rear shock advice [yet again] | tonny006 | SV Talk, Tuning & Tweaking | 7 | 22-09-08 04:49 PM |
zx10 rear shock basic settings | Marksv | SV Talk, Tuning & Tweaking | 25 | 15-04-08 02:49 PM |
zx10 shock | skapegoat | SV Talk, Tuning & Tweaking | 10 | 20-01-08 10:02 AM |
ZX10-R '04 Rear Shock - Curvy Upgrade | pmapp | For Sale - SV's and SV related items | 5 | 01-10-07 09:02 AM |
