Old 12-02-10, 09:11 AM   #11
Lucas
Default Re: Battery Life & Alarm Question
I now got a spare battery that lives in my flat charged up, its a good plan. Nothing worst then getting all kited up, turn key and nothing happens!
Old 12-02-10, 12:11 PM   #12
sunshine
want to here the easy solution? buy a Xena disc lock alarm, no worries about the bike battery then.
Old 12-02-10, 12:20 PM   #13
ThEGr33k
Put it on a tender once a week for a couple of hours (till its charged basically). This will get rid of all issues and keep the battery in tip top shape. From what you say to TLW this is hard? You can get 50 meter extensions though, surely that would be enough???
Old 12-02-10, 12:44 PM   #14
Biker Biggles
Biker Biggles's Avatar
Agreed.It does'nt have to live on the Optimate.A couple of hours charge once a week should do it.
Old 13-02-10, 12:05 PM   #15
petevtwin650
Can you not buy higher capacity batteries, that also resist cold weather drain (Gel or calcium)?
Would be expensive to buy but would also be the easiest option and give peace of mind.
Old 13-02-10, 12:21 PM   #16
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Cheers for the input guys.....
I have decided that the simplest option is that at LEAST every 2 weeks the bike will get a decent run out from now. The exception being when we hit September at which point it will be SORN'd.......we are then going to get a second battery and an optimate for through out the winter.
"Feckinnnn Unluckkeeeeeeee"
Old 13-02-10, 12:25 PM   #17
sunshine
weekend warrior on 3 ride outs a year run it daily! even through the cold winters!
Am i still included in the madlanders rideout your organising or you going to kick me off it ?
Old 14-02-10, 06:35 PM   #18
ThEGr33k
Actually, As the temp goes down drain from a lead acid follows it. Lead acid lose voltage faster the hotter they are...
As to larger battery, certainly does help! Judging from the picture you have a 955i? My old man has a sprint st and is now running a 14aH 220cca monster battery!
Battery life? forklift SV Talk, Tuning & Tweaking 8 10-06-09 02:24 PM
alarm draining out battery abdul.aziz SV Talk, Tuning & Tweaking 2 10-05-09 12:56 PM
my acumen alarm carnt see the battery Smudge Bikes - Talk & Issues 0 09-07-07 01:59 PM
Battery Life scousegit SV Talk, Tuning & Tweaking 12 03-07-05 09:31 PM
Datatool Alarm and Charging the battery ? PSJ SV Talk, Tuning & Tweaking 2 24-05-05 08:20 AM
