Old 21-03-10, 07:20 PM   #11
Biker Biggles
Biker Biggles's Avatar
Default Re: Oh dear!
Right all done, two possible places for the oil leak.
1, strange bolt on bottom of crank case, may be a secondary drain hole. Bolt head is fitted with a tabbed plate to stop working loose. Tabbed plate seems to be made from mechano, but not as hard!
2, oil drain plug was hugely over tightened. It does not have a copper washer and tightens against a smooth surface. If it continues to leak from here, I will fit a copper washer. Strange that they would not fit one.
Other issues, the oil drain plug had large flakes of metal on it and some filings. However, I saw worse when the clutch plates on my old CG went. The oil filter had metal flakes in it that could be measured with a kids school ruler! Three to five mm in size... Eek.
The sump contained about 750ml of oil. To get it back up to the right level, I put 1.5L in.
The chain was sagging by about two inches and when the bike was sat on, would go down to about an inch and a half. I adjusted this to the inch recommended in the owners manual.
The exhaust is rotted out fully and needs replacing. It has hardly done any miles but it look like it has been left on the sea front for ten years of bad winters.
This is a heavy bike, moving my SV after felt quite easy. Usually after moving my 125, the SV feels like it is cast lead. Mind you, I can lift my CG off of its wheels on my own, not with this one.
That reads like a good argument for getting rid of it to me.
When BB junior had one you couldnt get cheap exhaust replacements either so beware of that.
Old 21-03-10, 08:50 PM   #12
The one the front fell off?
http://www.youtube.com/watch?v=7rUQbTsc_ms
Old 21-03-10, 09:00 PM   #13
5hort5
is the bolt on the crank case just not a secondairy oil drain plug ?
Just on this point m8, it does have oil behind but you can't drain it all out from there. It's a hole that enables other things during the making of the engine Zadar put it much better when I was asking about it on my curvy but I believe the pointy is similar, see his pics:
http://forums.sv650.org/showthread.php?t=145570&page=2
5hort5 is offline   Reply With Quote
Oh Dear Oh Dear...The problem with fitting a BMC Filter and rejetting is............. Dappa D SV Talk, Tuning & Tweaking 36 15-09-08 05:24 PM
oh dear oh dear - summertime Balky001 Bikes - Talk & Issues 53 27-06-08 01:53 PM
oh dear... Draper Bikes - Talk & Issues 31 12-12-07 09:52 PM
oh dear oh dear oh dear keithd Idle Banter 17 10-11-06 08:01 PM
oh dear madmartyn Idle Banter 18 10-05-06 06:22 PM
