View Poll Results: What type of Fuel do you use: | |||
Normal Unleaded - bog standard stuff |
29 | 78.38% |
Premium Unleaded - The more expensive stuff |
8 | 21.62% |
Voters: 37. You may not vote on this poll |
#11 | |
Go and understand the definition of the octane rating system before partaking in discussions about it ![]()
#12 |
The standard SV is designed to run on standard fuel so it's a complete waste of money to put anything more expensive in.
I sometimes use higher octane fuel in my MX5 Turbo in the summer when it's hot to stop the engine knocking. I think the only difference is that higher octane fuel is harder to ignite so is more knock resistant. |
#13 |
An SV engine is only good for about 250,000 on standard fuel, so perhaps use premium
If you're a frickin MOON COURIER! ![]() |
#14 |
I have no scientific knowledge, was just guessing, found this though:
"Octane reduces gasoline's tendency to auto-ignite, protecting the engine against detonation or pre-ignition. Manufacturers will recommend the minimum amount of octane necessary to protect the engine against damage. High compression engines tend to need more octane, because they are more susceptible to detonation." (http://www.active.com/lifestylevehic...ium_Price_.htm) AND Interestingly the TV programme "Fifth Gear" tested these two fuels against normal unleaded with three different cars: Renault Clio - and found that the premium fuels made no difference to the power output of 81bhp VW Golf GTI - Found that Ultimate increased power output from the standard 172bhp to 174bhp and Optimax increased output to 177bhp. Subaru Impreza WRX STI - found that power increased from standard 235bhp to 248bhp with Ultimate and 249bhp with Optimax. (http://savefuelsavemoney.co.uk/carfuelsave3.htm) |
#15 | |
... ...hence the cars in that list that work are all turbos! Here they can adjust for the higher octane fuel accordingly. Edit: that's a **** explanation. But I'm tired. |
#16 | |
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan Now: Blue FZ6 Fazer |
#17 | |
![]() Those cars all have a knock sensor so can take advantage of the higher octane rating.
#18 |
I've been using Shell Vpower for ages and ages. I find that it provides slightly better low down pick-up when on a tiny whiff of throttle; less snatchy than normal unleaded.
But tis too expensive now, so will be using 95 ron again. There is no significant gain to be had from using super unleaded fuels, at least many tests show no improvment when full throttle is used. I've not seen any tests though that show if super unleaded fuels give any advantage at part throttle...i'd expenct not, but it would be nice to see data showing what it does / dosn't do |
#19 |
#20 |
eye ball yellow "n" and a blue "s" curvey!!! | cymroboi | The Border Patrol | 5 | 19-06-09 08:09 PM |
Using "Pointy" Tensioners in a "Curvy"? | dtr125 | SV Talk, Tuning & Tweaking | 25 | 05-02-09 05:42 PM |
teh "what you doing this weekend thread"...sponsored by Chesley "Sully" Sullenberger the Third | keithd | Idle Banter | 30 | 18-01-09 11:47 AM |
Rideout "Sections" or "Groups" | independentphoto | Bikes - Talk & Issues | 19 | 04-09-07 01:08 PM |
Wanted "normal" level can mount - poss trade? | Jase22 | Stuff Wanted | 1 | 27-03-07 03:27 PM |
