Old 24-03-10, 11:53 PM   #11
punyXpress
punyXpress's Avatar
Default Re: Pointy bottom end into a curvy.
How much damage - helicoil wouldn't fix it would it?
@45000 it's just about run in.
Now: Street Triple R
Old 25-03-10, 12:24 AM   #12
cloister
Threads are stripped and the boss is cracked. You'd need to get the case welded, if that's possible, then fit a helicoil. That's if you can even get the now epoxy welded pressure switch back out. Still need to split the cases to do that anyway.
@45000, used all year and kept out on the street mostly uncovered it's still a perfectly good motorcycle so I don't want to break it. Newish bottom end and hopefully it'll be good for another 45000
Old 25-03-10, 06:06 AM   #13
zadar
Originally Posted by fastdruid View Post
The pointy cases are drilled for the cooler (blank on the curvy), I'm not sure if you can plug them, you could just put in a small loop though.
Druid
Just put short bolts with crush washer and you done.
All parts are interchangeable between two except transmission clutch shaft.
Like Yorkie said, need to use stator/rotor from curvy on that 04 bottom.
Old 25-03-10, 10:39 AM   #14
Default Re: Pointy bottom end into a curvy?
what is different in shaft? Can you use old clutch on new shaft?
Old 25-03-10, 04:09 PM   #15
zadar
New one is longer, inside motor. You can use all parts and move them around, you just can't take whole shaft and put in other cases. 99-03 is same, changed in 04. Same with cases, 03 are specific for that year only.
2000 CURVY Bottom Yolk! chompy For Sale - SV's and SV related items 0 10-05-09 02:20 PM
Curvy Bottom Yolk! chompy For Sale - SV's and SV related items 4 03-05-09 03:16 PM
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
SV650 K3 pointy - bottom yoke S model flymo Stuff Wanted 1 08-03-08 11:25 AM
Bottom Yoke for an SV650S (curvy) 21QUEST Stuff Wanted 9 16-07-07 06:49 PM
