Old 08-04-10, 08:27 AM   #11
Default Re: Stiff Gear Lever and Front Sprocket Torque
Originally Posted by Spanner Man View Post
On occasion, the bush inside the gearlever becomes tight due to the lever corroding behind the bush & forcing it onto the footrest.
You may have to remove the bolt holding the footrest to the hanger & get the lever off. These can be a dreadful pain, a good vice to hold the footrest is essential.
Once removed, sometimes one can rub the bush down slightly, but often they end up falling to bits Then it's either make a new bush of some sort. Or, get a replacement lever.
There's an echo in here
Old 08-04-10, 09:38 AM   #12
shelleyamy
Ah wind another bolt in there and hit the bolt, that will avoid peening those over. tickle it on the grinder to get rid of the raised bits
Yeah i was hitting the bolt, but i think previous owner must have been hitting the lug, and gave up,the dremmel is the next tool, if it dosn't loosen up today. Mike
Old 08-04-10, 01:43 PM   #13
Spanner Man
Originally Posted by shelleyamy View Post
Think your right,
I KNEW I was
Leave off! My eyes don't work well in the morning
Spanner Man
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
K6 light blue/silver front fairing,indi's,gear lever. Baz M Stuff Wanted 4 18-05-07 07:10 PM
Gear lever & front indy Cookie Stuff Wanted 0 17-04-07 03:14 PM
Stiff Gear Lever fizzwheel SV Talk, Tuning & Tweaking 2 09-09-06 02:42 PM
Clutch lever is very stiff The Mass SV Talk, Tuning & Tweaking 2 08-06-06 12:48 PM
