#11 |
The RC30 is the bike that tops my wish list if I ever win the lottery.
I came ---> <--- this close to buying a brand new one in 1989, but my then girlfriend talked me into getting married and putting the ten grand savings I had down as a deposit on a house, and we all know what happened to the housing market and my marriage, don't we. One day I will own one |
#12 | |
#13 | |
#14 | |
Good morning all. I used to maintain an RC30, which was quite a buzz after many years of mass produced fodder. My customer bought it for £3000 due to a top end clatter. They're a bit like a Swiss watch inside - Engineering porn if you like ![]() Lifting the cams to shim the beggar was interesting to say the least. They have a scissor gear which is sprung loaded alongside the main camshaft drive gears. You have to insert a locking pin to hold them together when you unbolt the camshaft. The pin hole is 'conveniently' is down the drive tunnel. So it's a 'heart in gob' moment with magnets & rags everywhere. I turned out that a previous pillock ( I suspect it was the owner) had unbolted the inlet camshaft on the rear cylinder, & allowed the scissor gear to spring back. He had replaced the camshaft without re tensioning the gears, hence the rattle. There was no other damage, after shimming all the valves & balancing the carbs she was sweet. 3k- BARGAIN! It ran reliably for a couple of years, but unfortunately it was one of the RC30's that was affected by the soft valve seats which was a problem on some. Heads off, & wallet out for the owner, along with the words, 'help yourself'. It was interesting to work on, the only downside is that everything for an RC30 is around 3 times the price of that of a 'normal' road bike. Head gaskets were a 'HOW MUCH' moment. Cheers. P.S. If you ever get to ride one you'll wonder why anyone bothered with fuel injection. The carburation is sublime. |
#15 | |
#16 | ||
#17 |
![]() Last edited by plowsie; 14-04-10 at 08:53 AM. |
#18 | |
![]() By all means! & bring your wallet too! ![]() Quote:
It was indeed Tony Scott who I sent the heads to for the sorting of the valve seats. I wasn't going to trust any of the others in that trade with a pair of RC heads. There's no mystique to these so called 'Exotic' engines. They're only nuts bolts & components. Exactly the same as any other engine. Just more expensive that's all. Cheers. |
#19 |
#20 | |
![]() Only thing trickier (or significantly different[1]) from a normal service POV to the RC24 as spannerman says is the valve clearances (RC24 uses tappets with locknuts). I am curious as to how someone managed to have the anti-rattle (scissor gears) on the cams missfitted though, all the ones I've ever seen (NC30/NC35/MC17/MC19/MC22/RC24,RC37) only ever sit at most out by half a tooth when off. Although the RC30 may have been rather different in that respect. Druid [1] Well apart from almost every part being different by being lighter/smaller etc. ![]()
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F Last edited by fastdruid; 14-04-10 at 09:45 AM. |
For sale: CCM RC30 | cuffy | For Sale - Other Bikes and General biking items | 5 | 08-03-10 06:44 AM |
Vfr750 rc30 | BanditPat | Bikes - Talk & Issues | 34 | 24-02-10 09:47 AM |
how do you keep it fresh with OH | newman | Idle Banter | 61 | 08-11-09 06:56 PM |
Bike P*rn - RC30 Promotional Video | rigor | Bikes - Talk & Issues | 16 | 30-06-08 06:15 PM |
Fresh Meat!! | Frank O | Idle Banter | 7 | 16-01-06 09:47 AM |
