Old 24-05-10, 08:10 PM   #11
sinbad
Default Re: blipping
I'm amazed how often this topic comes up for discussion, and by the stubbornness of some of the people who claim it's useless or unnecessary or simply not worth bothering with.
The theory is so simple to understand. It just works.
Everyone should be able to do this, even if they choose not to (for some reason). It's as much a part of riding a bike as anything else imo.
Old 24-05-10, 08:11 PM   #12
simesb
Originally Posted by muddi View Post
Cant say ive ever noticed the bike 'coasting' as when changing down I try to get speed right first by braking then quick change down with revs off, back on again once changed (depending on what ive slowed down for obviously lol)
With that approach you may be at the right road speed for the gear, but not the right engine speed for the gear you are going to be in.
Old 24-05-10, 08:12 PM   #13
TBH I think explaining it is harder than doing it!
Old 24-05-10, 08:15 PM   #14
Amanda
This is exactly the same thread I had a while ago. I now blip the throttle all the time - makes SO much difference.
Basically you pull in the clutch , down gear and blip throttle then let out the clutch. It's pretty instant and the ride is smoother cos the higher revs match the lower gear. Before I blipped I noticed you get a jolt when you change down gear.
Old 24-05-10, 08:18 PM   #15
sinbad
The crazy thing is that that's true!
But the theory is simple. I think riders who don't recognise the need for it simply do not try to slow down with any great urgency for corners. You can get away with it if you ride like that, "there's no need".
Old 24-05-10, 08:19 PM   #16
simesb
Blip very slightly before the down change, not afterwards. In practice it's almost instantaneous which I guess was why you wrote it like that
Old 24-05-10, 08:21 PM   #17
muddi
know what you mean by that but I listen to the engine noise for gear change than look at actual speed etc, so far fingers crossed not made a bollox of it yet lol....
oh apart from when first got the bike and dropped to a too low gear as thought I was in a higher gear than I actually was going round a downhill hairpin at time and locked back wheel - oopsie! Just pulled clutch in and kicked up gear rather sharpish haha, brakes were on a tad already..
Might just give it a go and see how I do with it - like someone said - be a bit weird trying to brake and blip at same time... suppose ya never know till ya tried it!
Old 24-05-10, 08:21 PM   #18
Mr Speirs
Mr Speirs's Avatar
In my humble but correct opinion the SV is practically unrideable at pace without blipping the throttle.
You let the clutch out quickly you give you arms and wrists a knackering not to mention to balls to tank altercations.
You let the clutch out slowly and you find as you are slowing down you are constantly feathering the clutch and hardly ever in the right gear.
Old 24-05-10, 08:27 PM   #19
Seggons
Things become really interesting when your braking with the front and rear brake while at the same time downshifting with a blip.
Old 24-05-10, 08:28 PM   #20
christian1000
With braking and blipping the throttle, is it best to use two or four fingers on the front brake lever? Or is it just a matter of preference?
Blipping the throttle Holdup Bikes - Talk & Issues 50 16-12-09 10:06 AM
Blipping the throttle ArtyLady Bikes - Talk & Issues 30 30-06-09 05:56 AM
Blipping the throttle after changing down a gear. Ruthja2801 Bikes - Talk & Issues 88 25-02-09 02:30 PM
Blipping the throttle. petevtwin650 Bikes - Talk & Issues 151 02-06-08 06:46 AM
Is there a big disadvantage to not blipping the throttle on fast downchanges? monkey Bikes - Talk & Issues 25 06-04-08 02:43 AM
