Old 24-06-10, 01:41 PM   #11
G
Default Re: Motrax Rip Off Merchants.
Good luck, is there a proper thread that your posting updates on rather than there being lots of little ones with support.
6.67300 × 10-11 m3 kg-1 s-2
Old 24-06-10, 01:51 PM   #12
ThEGr33k
Has anyone got a picture of what it is you are talking about? Taa
Old 24-06-10, 01:52 PM   #13
danf1234
yeah ditto I have no idea what you are on about?
Old 24-06-10, 01:57 PM   #14
Luckypants
Luckypants's Avatar
See here http://www.fixer-peg.co.uk/
Davie's smart idea for a get you home gear / brake lever repair after a minor spill breaks off the toe peg. Speedy had hers on for almost 12 months, it's that good.
To my mind it's essential bit of kit, along with spare bar levers, cable ties and gaffer tape.
Old 24-06-10, 01:58 PM   #15
btw Davie, why do you use 2 grub screws when 1 will do?
Old 24-06-10, 02:18 PM   #16
DavieSV
DavieSV's Avatar
It uses three.
One down the centre to clamp it flat to the lever and two small ones to keep it centrailised.
DavieSV is offline   Reply With Quote
Old 24-06-10, 02:23 PM   #17
Nobbylad
Nobbylad's Avatar
Have had one under my pillion seat almost since I bought the bike 2 years ago. Have used it after both my offs and it's paid for itself many times over as a result. It was the difference between getting home or not from Anglesey after my 1st track day and I always keep it with me for when I, or someone else needs it.
Good luck Davie!
Old 24-06-10, 02:26 PM   #18
Originally Posted by DavieSV View Post
It uses three.
i was on about the ones to keep it centralised. one would do the job just nice and save on parts and machining in turn getting the cost down further.
i'm no engineer but it makes sense to me.
Old 24-06-10, 02:41 PM   #19
DavieSV
DavieSV's Avatar
It is designed to fit various levers of different bikes, so the hole that the lever fits into is larger than it needs to be to fit just an SV lever.
If it was to clamp on just the top or the bottom, the toe-peg would be either too high or too low.
Make sense?
Old 24-06-10, 02:57 PM   #20
i wouldn't have thought a couple of mm would have made that much of a difference.
supose you have tried all options and come up with the best.
i'll shut up now
Which stands to use? Motrax or?? 600+ Bikes - Talk & Issues 3 10-07-07 10:01 AM
Motrax indicators - new Girth For Sale - SV's and SV related items 1 04-06-07 11:51 AM
motrax rsend2 Quiff Wichard Bikes - Talk & Issues 2 08-04-07 10:14 PM
Motrax DHM? Jase22 SV Talk, Tuning & Tweaking 24 14-11-05 07:00 PM
motrax l.e.d.s (again) stumpy1 SV Talk, Tuning & Tweaking 11 19-04-05 06:00 PM
