#11 |
I had fun like that with the SV... with mine there was a small rubber bung that had come out of the front carb and it was sucking air at low revs so there wasn't enough fuel in the mixture. Bung back in taa daa!!!
Let IP have a look!!!
Innuendo - it's great when you get it. sv650s (gone) gsx-r600 (gone) Street R675 (now living in Inbhir Nis ) |
#12 |
Hello. Yep, as said above - quick 10 minute balance check before going down the carbs off route. Might save you a whack, nothing to lose anyway as most carbed bikes go off balance every now and then.
#13 |
managed to get it to idle which is a start a suppose lol 1ns a get it looked at i think a good service wouldnt go a miss
#14 |
Welcome, im new myself they seam like a sound bunch, so far!! Mite see you out on one of the ride outs soon.
#15 |
#16 | ||
preceeded and followed by 30 mins of strip down / rebuild for access
how old is the bike, pointy (03->) or curvey (<-03) how many miles when was the last service? how long has it been sitting may be advisable to drain fuel and clean out tank. realistically what does it need. oil and filter (& crush washer) Spark plugs air filter check brakes, lube & possibly pads brake and coolant level check battery / reg/rec check chain / sprocket fuel filter fork seals check wheel bearing check check tyres (esepcially if its been parked up for a while) |
#17 |
i'll give you an update re-philpys bike- he brought it over and left it with me for a few days,was idling really bad refusing to start sometimes,every nut and bolt seemed to be welded together,choke plungers also welded into carbs, usual suzuki cheese screws which melted on seeing screw driver,carbs were in very bad condition,full of jellied rusty gunk,so different set of carbs, front and rear coil,nuts and bolts/clamps replaced, and new choke cable etc,carbs balanced - bike seems to be running better and smoother but still hunting occasionally a bit on idle, occasional fart out the exhaust.Checked for air leaks/ loose connections but nothing found. Engine needs oil and filter change and needs the valve clearances done( no record of ever being done and nearly at 32000) and a full service(leaking fork seal also).
Cam chain is really loud and front tensioner could do with being replaced too. Ive spoken to philpy re the condition of his bike and what he'd be looking to spend to get it back in a semi decent condition and he's looking at a good few quid-there's a few other bits and bobs to be done to get it looking decent- i honestly think that his bikes at the stage where its gonna cost him more to get it back to decent condition and keep it there than the bikes worth. He's gonna get shot of it and is heading towards a pointy. |
#18 |
Got a bit of interest in the bike so heres hoping i can get it away and get a pointy. Thanks again husky for the help
#19 |
Bike is now sold been told bike was running on 1 cylinder as husky said the bike was gettin to the stage were it would have cost me a bit of money to upkeep. Now on the look out for a pointy in the next few weeks.
#20 |
good mate here's hoping you get another soon
Newbie to all newbie’s and experienced riders / question. | tonyk | Bikes - Talk & Issues | 17 | 03-06-08 08:12 PM |
MAG - Glasgow egg run | carelesschucca | Idle Banter | 6 | 17-01-06 11:23 AM |
