Old 08-07-10, 06:46 PM   #11
Razor
Default Re: k2 curvy running problem
did it run ok after the 2 washers were taken out?
Old 08-07-10, 09:38 PM   #12
Nicky S
Nicky S's Avatar
yer it run fine
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 08-07-10, 09:42 PM   #13
does it stink of fuel out the back? sounds like it could be a stuck float.
Old 08-07-10, 09:44 PM   #14
Nicky S
Nicky S's Avatar
right have spent the last few hours looking over the bike and think i might have got it.
when i have the bike running holding the revs at around 2.5k to stop it from stalling there is a sound that comes from the front carb on the front head that sounds like blowing air (is there only way i can explain it)
so i am ever losing compression at the spark plug or leaking around the head .... but then again mabey not as there is no oil ec.
the nosie also sounds like it is coming from the front carb so i have had them off the bike and looking over them i found this.
this is were the choke goes into the front carb as you can see the mount is broken do you think this has anything to do with the problem i am having? as the choke could always be on meaning its throwing to much fuel in ?
also as you can see i F****D the screws to try and undo them i still have not got them undone
Old 08-07-10, 09:46 PM   #15
You need to learn how to undo stubborn screws.
http://www.youtube.com/watch?v=uc7uyMs-YtQ
chokes are a possibility. While you have carb off take float bowls off and check for crap.
Old 08-07-10, 09:55 PM   #16
Nicky S
Nicky S's Avatar
nope no smell of fuel
Old 08-07-10, 09:58 PM   #17
Nicky S
Nicky S's Avatar
YC lol nice video
so if there is crap in my float bowl it is problem a stuck float ?
Old 08-07-10, 09:59 PM   #18
could be stuck float giving too much fuel, are the plugs wet?
or it could be a blocked jet giving not enough. Just generally look over the carbs, is there loads of carbon deposit on the backs of the butterflys?
Old 08-07-10, 10:07 PM   #19
Nicky S
Nicky S's Avatar
nope plugs arnt wet has brand new ones init
nope the butterflys are as clean as anything
Old 08-07-10, 10:45 PM   #20
Biker Biggles
Biker Biggles's Avatar
So many curvy running issues are down to dodgy choke plungers.You need to get that mullered screw out and check the innards.And the other cylinder.
Fazer running problem. warrenhewitt10 Bikes - Talk & Issues 32 06-05-10 06:04 PM
running problem - as if running out of petrol Nick8529 SV Talk, Tuning & Tweaking 20 27-10-09 11:47 AM
sv running problem? any ideas Crunchy SV Talk, Tuning & Tweaking 6 31-07-09 04:27 PM
And you thought running out of oil was a problem... gettin2dizzy Idle Banter 22 11-06-08 08:04 PM
Odd choke/running problem northwind SV Talk, Tuning & Tweaking 13 07-06-05 11:46 AM
