#11 |
Thanks guys
![]() Re: the drain plug issue - I only removed this one as bike was on paddock stand at the time whilst doing other major service items and removing fairings etc. - I have previously used the normal bolt when on sidestand as you mention, possibly hence not finding this before now. Gonna refill oil and do another oil change after a short interval of c.500miles to see if anymore comes out or it all starts falling apart, but hopefully not! ![]() |
#12 |
You usually find rubber bands from first clutch plate under there heh.
It is fine to use that drain, but you have not removed all the oil, there will be a bit left by normal drain too. It is the cap underneath oil strainer, left over from where passage inside casing is made.
#13 |
Well, after finding the shavings, I did drain again from normal plug on sidestand - absolutely nothing untoward in this last half-cupful or so...
Anyway, have since come home this evening and refilled oil. Cranked on starter without choke to fill filter and build pressure - light went out immediately so cranked for further 5-10 secs. Stopped, pulled half-choke and start up as usual - no problems and no noises as usual - so far so good... Gonna ride it for a tank of fuel and drain oil again and meticulously check for anymore debris etc... Hopefully, it has just been a case of finding something that is probably in most motors under oil pump strainer but not normally detected... |
#14 |
quick update - just done a steady 20 miles - nothing to report so far; no news is good news...
#15 |
So, now 350miles (not so steady) further on and still nothing to report - have also drained oil again and absolutely clean/clear - fingers crossed nothing nasty afterall...
#16 |
Probably swarf from initial build - was it made on a Friday?
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
Metal Britannia | thedonal | Idle Banter | 8 | 08-03-10 12:42 PM |
Liquid Metal | DarrenSV650S | Idle Banter | 42 | 06-04-09 03:31 PM |
can anyone identify this bit of metal | 454697819 | Idle Banter | 3 | 17-06-08 09:53 PM |
Heavy Metal | Alpinestarhero | Idle Banter | 67 | 31-12-07 12:09 AM |
why? is heavy metal called heavy metal | pegasus | The Essex Lounge | 14 | 09-06-05 07:26 AM |
