View Poll Results: Back brake absolultely knackered after trackday - what's the cause?
Brake fluid has boiled - renewing it will fix the problem 2 25.00%
Boiled brake fluid has made the brake line stretchy and spongeyriffic 0 0%
The pad is well past it so that's prolly why the lever is hitting the stop 1 12.50%
a combo of all 3 5 62.50%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Old 27-08-10, 10:29 AM   #11
davepreston
Default Re: Back brake absolultely buggered after trackdays
tune for vid
leaving on a jet plane
somethings gotta give
falling in love is hard on the knees
Old 27-08-10, 10:34 AM   #12
Paul the 6th
Paul the 6th's Avatar
Originally Posted by DaveWalker View Post
you use the back brake on trackdays!!!??? I've only ever used it at Cadwell over the mountain and a little bit where there's that horrible crest on the back section of Oulton. Certainly not enough to cook the pads though. It sounds like it's just boiled - bleed it and it should be fine. Are they braided lines or standard?
Originally Posted by flymo View Post
only thing my back brake does is keep the scrutineers happy
you'll see on the RAF leeming vid there's a bit where I run into a corner too hot - if my back brake had been working properly I reckon it would have just about scrubbed enough speed to stop me running 2 ft onto the wet grass...
Tis nice to shave some speed of gently sometimes - me and irksy dan both do it, and there's nothing gay about it thank you very much.. (love you dan xx)
Old 27-08-10, 10:58 AM   #13
Irksy dan who fell off from losing back tyre at last one?
Nothing to do with rear brake... you were distracted by my sexy leathers.
Old 27-08-10, 11:29 AM   #14
Paul the 6th
apparently that was due to a squared off tyre? those comedy 90's leathers did actually dazzle me a bit, hence why I tried a bit of motorcross over wet grass on sticky touring tyres
Old 27-08-10, 11:41 AM   #15
Berlin
+1! I have rear race pads and a wavy rear disc that have never been used
But then I missed a gear and proved that the SV can indeed rev to 13,000 rpm.
I sharn't (a much under used word) be doing that again soon!
C
Old 27-08-10, 11:42 AM   #16
Berlin
you'll see on the RAF leeming vid there's a bit where I run into a corner too hot... (love you dan xx)
If we live long enough!
Old 27-08-10, 05:38 PM   #17
Red Herring
Red Herring's Avatar
Default Re: Back brake absolultely knackered after trackdays
I only remembered my track bike had a back brake when the front ones failed....
I guess it's possible you're been "comfort" dragging it a bit and overheated the fluid, especially if it's fairly old anyway. Change the fluid, give the pistons and surfaces a good clean/lube and check all moves freely, then leave it alone!
How (not) to clean the back brake carternd SV Talk, Tuning & Tweaking 2 02-05-10 08:07 PM
Do you use your Back brake? Berlin Bikes - Talk & Issues 55 03-09-07 02:08 PM
sticky back brake on yer bike Bikes - Talk & Issues 4 16-11-06 05:53 PM
Back brake not activating brake light. quikstu SV Talk, Tuning & Tweaking 3 19-06-06 04:05 PM
knackered brake seals - how much? Dirty Baz SV Talk, Tuning & Tweaking 27 11-01-06 07:37 PM
